Deck Staining Proje...
Deck Staining Project Questions
(@gmarsh)
I am looking for a little help on stain brands and products.  I have a large covered wrap around porch on the front of the house that is approx. 20 years old located in the Upper Midwest.  I am in the process of sanding down and re-staining the deck to a different color.  So one of the issues that I am running into is a mixture of different species of wood.  The floor is T/G Douglas Fir, the trim and stairs are cedar, and the posts are pressure treated along with the skirting that I am replacing.  I am looking between a semi transparent and semi- solid stain, but concerned about durability since this is the main entrance into the home and also color differentiation (looking at a dark brown color) due to the different species of wood.  I am hopeful that I should be able to get 95% of the deck to fresh wood, it had a solid redwood stain before.  Any recommendations on stain brands? Looking through reviews I am thinking either Cabot or TWP if I can get it close.  It looks like there is a dealer around 50 miles away.  I would like to have a product that I can restain by just cleaning in the future without the sanding prep that I am doing now as the stain wears differently with traffic.   Also, since I am replacing the skirting and the railing with new green wood what will happen if I stain the wood right away and don't let weather.  Will the stain just not hold?
Thanks in advance
TWP Dark Oak or Armstrong Clark in Rustic Brown. If you stain the new wood without the weathering, it will most likely fail within 12 months.
(@gmarsh)
I found a location that sells the 100 series TWP today and liked the look of dark oak and that is the color I am leaning towards.  If the stain on the new wood fails in 12 months do you think that I will be able to just re coat without a whole lot of prep and cover the old stain?  Just a cleaning and restain?
When staining new wood with TWP and not weathered or prepped, the TWP does not soak in very well and could dry with some drip marks and look "blotchy". When you have to redo, you will most likely need to remove it and start over.
(@markkelly)
Recently I built a new deck and have no idea how to preserve the natural wood color and would appreciate any advise.  We live in Connecticut and the deck has a NW exposure, sun hitting it from from 1:30 PM on.   Can you point me in a direction.
See this article to start:
(@markkelly)
