Kids Creations redw...
Kids Creations redwood swing set
(@g_91rw1aky_96-60-255-220)
I was given an 8 year old Kids Creations swing set. It has a LOT of solid redwood, similar to the following:
I think it was restained one time several years ago with a semi-solid stain, and I have already begun disassembling the pieces and sanding them down to bare wood.
What would a good stain be for this application? I live in East Tennessee with hot summers and mild to cold winters, and this swing set will get a lot of sun exposure.
I'd like a semi-transparent stain that results in a light brown color, but I have tested a few TWP 1500 colors and they all look very orange or red, obviously due mostly to the original redwood color.
I also don't want to go too dark brown -- the TWP 1500 Dark Oak and Black Walnut feel noticably hotter to the touch than the lighter stains and the bare wood, which wouldn't be good for a kid's swing set.
What about these?
Defy Extreme Light Walnut
Armstrong-Clark Rustic Brown
Penofin Nantucket Mist
Would oil-based be best for this age and condition wood? Also, do I need to do anything to the bare wood before applying the stain?
Also, how much stain would I need to coat this swing set properly?
Thanks for any help!
Of your choices I would think the Armstrong in Rustic would be best. Definitely oil based for this wood. 2-3 gallons should be enough.
Thanks for the quick response. Is it OK to apply that stain directly on the bare wood? I have been using 120 grit on places where hands and feet will be, but considered stopping at 80 grit on the other locations.
If you do not sand the wood evenly with the same grit then the stain make take differently and look splotchy.
