what to do?
(@peedor)
I have a deck that I stained with solid oil mix with semi -transparent oil.1 to 2. Tried to strip, did not work well. Rented vibrating sander, it also did not work well. I do not really want to belt sand the  deck. Lots of work. Might not be up to it. What would you recommend ? I know that solid oils are  not for very good for decks or is there one? Can you use latex over what I have left?PS. professional painter of 40 years. Tried something that did not work that well! Every other year had to go over it again. Did it for 10 years.
You do not have a choice but to power sand this off. Applying over it will not fix this.
