Can you use water-b...
Can you use water-based stain after previous oil-based stain used?
(@brian)
We live in Virginia and have a pressure-treated pine deck around a pool (salt-water) that receives mostly full sun.  It was built in 2013.  We applied TWP 1500 Honeytone in 2013 and again in 2015 (after using the Restore-A-Deck cleaner.)  I am a little disappointed that the TWP stain didn't last longer (2 years is about the longest we should wait between re-staining) and we have had mildew on the rails, especially the horizontal portions and some green algae in a few places.  Do you have a recommendation for a different stain that would last longer and perform better?  I saw the newer reviews for Restore-A-Deck stain and wasn't sure if I could use a water-based stain after having used an oil-based stain in the past.
2-3 years is the max you will get. Honeytone is the lightest tint inf the TWP and will always fade the fastest. For better UV protection, use a darker or richer color. To switch brands, you will need to strip off the TWP.
(@brian)
Thank you.  I have heard that some people put a small amount of polyurethane into the oil-based stain to make it stronger and to help it last a little longer.  Do you recommend this?  If so, how much?
That's is not true and will ruin the deck stain. Bad advice from This Old House episode.
