Uneven finish using...
Uneven finish using TWP Semi-Solid Pro on new wood
(@jisaac915)
I just stained my deck yesterday with TWP semi-solid pro. The wood is treated (pine I think) and I waited 7 months for it to cure before staining. I also did the Gemini kit for cleaning and brightening and waited a week before staining. I used a foam applicator. After the first coat I wasn't liking the results as it appeared like the stain did soak into the wood but was too transparent and very uneven and the color wasn't popping. So I decided to let the stain dry and I applied a second coat. The color is much deeper now, but I'm definitely still seeing some unevenness in the finish and glossy areas which makes me think I overdid it. Any advice for what to do? Should I just live with it and then reapply in 12-18 months? I've attached some photos too. Thanks!
There is not anything you can do at this point except fully remove and start over. Personally, it looks pretty good so we would not do that. The shiny spots will dull down.
