Stain wont dry
(@mntman)
6 yrs ago I stained my freshly sanded redwood deck with Flood oil stain and it turned out awesome, well now it needed a little help, there were several areas along the edge and end that gets a lot of weather. I power washed and did a lite sanding of the entire deck and the weathered areas got a little extra. I used the same exact stain a week ago and the stain is not dry yet. Stain was applied with a 3/8 nap roller (just like original application) in the shade of the afternoon temp around 88* with humidity around 20%. Need help figuring where I went wrong, wife is tired of using backdoor to go outside. See attached pics
Thanks for any help
Your prep was wrong. it should have been stripped. You now have stain lying on top of the old coatings that is unable to penetrate and dry. You may need to strip and start over to fix.
(@mntman)
So what stripper should I use, plants surround the edges (divorce proceedings if they are harmed..lol) and after stripping what other steps are needed, i.e. Power wash, sanding again and complete re-stain...might just go to plastic
It is not an easy strip to remove a newly (over applied) stain. You may need to strip a few times and the runoff may cause some harm in your close surrounding. Try the Restore A deck stripper. Another option is to cover it will this:
http://www.deckstainhelp.com/gulf-synthetics-deck-revive-review-2015/
Cheaper than composite or plastic wood.
(@mntman)
Could I just sand the stain off rather than using a stripper, I have a friend that refinishes floors with huge floor sanders, he actually sanded the deck before my initial 1st staining and if so what other steps would be required after
You could, but it may gum up the sanding paper to the point it will not work well. Your stain had not cured yet. I would ask him.
(@mntman)
OK, I will get his recommendation. So will the stain eventually dry/cure, any idea how long it might take, if so I understand that it would look blotchy (shiny/dull) but at least usable.
No idea if it will cure fully or not. Sorry.
(@mntman)
Understood, what about just one strip and then refinish heavy sanding...man I really messed up
(@mntman)
Thanks for your time and info.....
