Old solid stain chi...
Old solid stain chipping... can I clean and re stain?
(@sesty)
moved into a new house With a large deck. Stain is flaking in spots and we have to replace 2 boards.
It’s a solid maroon color and we are looking to restain over it with a solid stain of a similar color.
Since we plan to use a solid - can we just clean and restain or do we need to strip and san first?
thanks
matt
You cannot strip a solid stain fully. Just clean off what is loose and stain with a solid stain again
(@sesty)
Great thanks you so much for the help!
Would you recommend a quick power wash over sanding to kick loose what’s left?
Yes, you will need tp pressure wash to clean and remove all the loose stain.
(@mkedryna)
Hello, just found your site and have been reading thru lots of helpful articals with great tips. I gave a similar sytuation with an older deck coated with solid red stain. Can you recomend product to restain? Thanks for your help Mike
Try the Flood Pro series solid stains.
(@sesty)
Got a sizable gift card to HD so went with Olympic Maximim solid water based stain in a similar color.
Overcast and 58°... then We got rain about 8 hours after finishing the first coat.
Some small spots are covered in many tiny bubbles. Can I sand these sections and re stain?
its possible the wood was not totally dry before stain was apllied since we had gotten rain 2 days before and it’s wet with dew every morning.
You can try to sand and reapply in those areas. As for why it happened, it could be many things. Moisture under the stain is probable.
(@sesty)
Appreciate the response...
had a full day of sun and wind today. Bubbles seemed to have worked themselves out. Left a slightly rough surface.. will lightly sand and throw down another coat if we get a few more days of sun this weekend
