Horizontal Fence - ...
Horizontal Fence - Wood, Stain, and Timing?
(@nacho)
We live in San Francisco and we're installing a new horizontal fence along the property line. Unlike other areas in the bay area, we get more fog and moisture in addition to sunshine.
Wood options we're considering are 1x8 redwood or red cedar. Locally, these both appear to be smooth on one side and rough on the other. Cost is similar; I know redwood is better for longevity and maintenance, but leaning towards cedar because of the base color being closer to the existing composite deck (Timbertech Tigerwood ) which has more of a golden hue.
I've read the articles here and elsewhere, but seeing some conflicting info so asking for specific advice:
1. For what we're describing, would you recommend redwood or red cedar fencing boards?
2. For the wood you recommend, what stain do you think would produce a similar color? (Also attaching a picture of decking material)
3. For the wood and stain you recommend, how long should we let the fence sit unfinished before we stain?
1. Does not matter.
2. No pictures. Wood type will not matter when trying to color match, it will be the stain and you will have to test colors as it will vary.
3. https://www.deckstainhelp.com/how-long-should-you-wait-to-stain-a-new-deck/
(@nacho)
Thanks! Sorry, somehow the picture got dropped. Here it is; recommendations for stain appreciated.
(@nacho)
Also- regarding drying time, I do see for kiln dried wood, you recommend a 1-2 month waiting period. The wood stocked locally for fencing is S3S, so one side smooth, the other rough. Does that change the recommendation (lumber yard says this can be stained immediately).
You cannot get wood to match this color of the deck unless you go with high solids like a solid stain or semi-solid stain. Mountain Cedar by Armstrong Clark might be close but you cannot apply it to new wood until it seasons for 12 months.
It cannot be stained right away.
