What do you suggest...
What do you suggest for best deck cleaners in 2024?
sp decks
(@sp-decks)
We have been using Behr Deck Cleaner and Strippers. What would you suggest for better performance and less expensive options? We are mostly pressure washing but we do like to use proper prep products so the wood does not get damaged.
Posted by: @sp-decks
Behr prep products are not very efficient and cost more than normal. Very the best price, you would want powdered prep products. They come in Wood Deck Cleaners, Wood Deck Brighteners, and Wood Deck Stain Strippers. Each powdered concentrate makes roughly 5 liquid gallons. No reason to pay for water 🙂
Look at Restore-A-Deck Prep Products. They work great!
Reviews Here:
Do you have any other questions? What are using currently to strip solid stains?
sp decks
(@sp-decks)
Posted by: @administrator
We have never had luck stripping solid stains so we typically recoat with another solid deck stain. Do you know of a product that removes solid color deck stains?
Yes. The RAD PaintStrip will remove solid stains or paints. See here for tips:
sp decks
(@sp-decks)
@administrator Thanks, Scott. Do you know if they offer samples to test out the RAD PaintStrip?
sp decks
(@sp-decks)
Can you give me some tips on how you would fix this side deck? Would you strip it or clean it?
IMG 3859
Yes: https://www.restore-a-deck.com/rad-paint-solid-stain-stripper-sample-size.html
IMG 3859
Are you using the same stain brand and color or switching?
sp decks
(@sp-decks)
We do not know what is on there now so switching. We want to try the Restore A Deck stain since it can be done on the same day as prep.
@sp-decks Strip and Brighten. This will ensure your new stain properly adheres and penetrates.
sp decks
(@sp-decks)
@administrator Thank you for the help, Scott!
