Have a 1yr old 800 sq.ft. purple heart deck. Originally sealed with Messmers UV for hardwood. turned a dirty greyish brown. Called wood supplier said needed cleaning to restore color. Tried Flood with no effect.Then tried Penofin cleaner, followed by brightner with little result. Wood seems to have some of the original color while wet but reverts to dirty brown when dries. Any suggestions as to how to restore color & finish to use.
Please add a picture by hitting the "reply" tab above.
I have tried several times to send pictures as per your request.I guess you are not getting them for some reason. If you will provide me an email address I will send from Iphone. If you can't do that any help you can provide will be appreciated. Thanks
pics of deck
Use the Restore A Deck Cleaner and brightener kit with a light pressure washing to restore the wood color.
Your advice worked. New question! Can I use remaining TWP 100 to seal interior
brick pavers.
No that will not work 🙂
