Stain for new cedar siding?
(@matteokeary)
We have put an addition on our Greek Revival house, and decided to go with cedar clapboard for the siding. The siding has arrived - "aye" or better, graded to the rough side, which will face outward. I had been considering the Behr premium semi-transparent stain, in Cape Cod Grey, based on positive reviews in Consumer Rpts... Until I dug deeper into actual user reviews.
Now I am searching for the "right" product. I have found the information here at DeckStainHelp very useful, but note that there are some specific recommendations which vary from what I've read elsewhere with respect to siding.
1) I have read that siding is better if stained on all sides before going up, to minimize cupping from differential moisture penetration front & back. This site suggests decking should be installed, aged x months, then cleaned & conditioned prior to staining. Is there a product that works better for immediate staining of siding before install? I am only really concerned about the rough side, since that will face out. I have used a moisture meter, and the clapboards are in the 8-10% range.
2) hmm, thought I had another example, but can't recall, pre-coffee.
In short, what is your top recommendation for new cedar siding, rough side out, when intending to stain all sides pre-installation?
I am willing to go oil- or water- based, as long as peeling isn't an issue ... It seems to me that with the overlapping siding, I want to just recoat every few years, not try to strip up to/under the overlaps.
We live near Ithaca, NY... Winters can be deep/cold (-15F)/longish, and summer highs up to 100F.
Thanks much,
Matteo
1. If rough you can stain right away with no need to let the wood season for some time.
2. Ok
Armstrong Clark in the Driftwood Gray if looking for a gray color.
(@matteokeary)
Thanks much for the quick reply - as a follow up:
What advantage has the Armstrong Clark over either of the top rated TWP options? I'm just trying to get a feel for what aspects make a product preferable for siding vs deck use.
Best,
Matteo
Well TWP 1500 does not have a gray so that was one reason we suggested the AC. The other is that AC penetrates deeper into new wood than TWP will. Verticals always last 2-4 times longer than a horizontals surface will.
(@matteokeary)
Super, thanks. I will likely try to get grey samples of both the AC and the TWP 100. Will report back here with decision and outcome.
Matteo
