Hard work
1 Reactions
(@whidbey)
Eminent Member
We have the same cedar deck. I cleaned it two years ago and put Defy sealer. Last year was very wet. I am using Simple Green cleaner. I have to go foot by foot with my pressure washer to get it down to the nice wood. For the 1st time I am considering a stain over cedar to minimize my work. All products which have been used are water based. Is my amount of work normal?
You need a stripper and then a brightener for prep. Much easier and does a better job. Simple green is not effective.
(@whidbey)
Eminent Member
Will the retore a deck stripper harm plants/trees? the runoff will be over them. thanks
Cover the plants when working and then rinse with water when done.
(@whidbey)
Eminent Member
Just to clarify the deck has not been painted or stained. still ok to use the restore a deck stripper?
You need the stripper to remove the Clear Defy sealer fully.
(@whidbey)
Eminent Member
I used the RAD stripper and was very pleased with it. It was very effective. The deck is now exactly what it looked like when we moved here. Clean and natural. I am going to have it sanded towards the end of August and consider which application to use this season.  I will post a pic if I can figure out how....
Thank you for you help.
(@whidbey)
Eminent Member
IMG 1358
@whidbey Looks great!
(@whidbey)
Eminent Member
@administrator Thanks could not have done it without your expertise!!
(@whidbey)
Eminent Member
Continuing on I used Aussie Timber Oil on our rear deck last year. It help up very well and it was easy to strip and power wash off this year. I am tempted to use it on the deck pictured above. The most outer cedar board gets heavy weather. I want to stain that single board around the deck. I thought painting it while as the paint holds up year after year. Don't know if that would look "off". Ideas appreciated. Thanks
Sure you could try that.
(@whidbey)
Eminent Member
completed the Australia Timber Oil Natural on the front deck. I really like the look
I ended up painting the most outside board white and will post that as well.
(@hasser)
newbie in it
@hasser Looks great!
