Hello, I have a ten year old pressure treated deck in Omaha. It's about 14' x 14'. When I purchased the home I used a solid stain, and a few years ago I sanded it down and applied Behr semi transparent, which began peeling within six months.
My home has a walkout basement so there is an outdoor dining table under the elevated deck, so you see the bottom. The bottom of the deck and railings are a dark red/brown solid and the decking is a pale gray. The decking was installed with nails and several pop up each year. A few years ago I replaced the stair treads with one 12" board each (stringers were breaking off at some tips so two 6" boards wouldn't hold). Otherwise there is only one rotten board and several warped spindles.
Anyway, I'm ready to tackle it again and want to go with TWP 100. My questions:
Thank you for your help, I'm wanting to do the best job for the long haul, if it is just a couple hundred $ more but saves me a lot of time I'd prefer to go that route, but most of all want the way that will last the longest and be easiest to maintain going forward.
Replace the deck boards and do a two-toned deck. Solid stain for verticals and semi-transparent for the floors. You will need to wait 3-5 months for the new flooring to season and you will need to prep. See these articles on new wood and two toned decks:
Stain the underside the same color as the railing.
