Removing just-applied stain
 TVM
(@tvm)
Apologies for posting in more than one section but I am seeking feedback on a few things.
Situation: made mistake of using Behr's semi-transparent cedar natural tone 7 years ago and now feel "locked-in" to the color, etc. Restained three years ago without issue. Doing so again this year, I have a problem: stain has not properly cured. 10 days after application, the stain feels very slightly tacky in places and can be lifted in strips with a mere scrape of a finger-nail, like a latex film. (Stain was applied when overnight temperatures hovered just over or under 50F and the second coat was applied overly thick - contributing factors I am certain).
Questions/feedback please:
1) What's the possibility the stain will still cure onto the surface and stop peeling?
2) If I opt to strip and re-stain again, will a good-quality stripper like Restore-a-Deck be effective in removing this very recently applied stain (i.e., as opposed to weathered stain)?
3) Can I get away with spraying stain over the railing spindles without stripping? (I might replace the deck outright in a year or so and just want it to look decent until that time).
Finally, if I re-do the whole thing, do I need to apply a sealer after the stain? (I used to think you either used a sealer/replement OR a stain on the native wood but not both).
1. Not possible
2. Very hard to remove newly applied stain. Probably will have issues.
3. Not sure but probably will have an issue.
Stains are sealers as well.
 TVM
(@tvm)
Thank you. That helps make up my mind - leave it as is and either restain or rebuild next year.
