Unknown oil or wate...
Unknown oil or water based stain - Pictures
(@crsschk)
Great site, very informative. Was reading elsewhere that I could post pictures of the deck I'm looking to refinish here and someone might be able to give me an idea of what finish is currently on it. Home was purchased about 6 years ago and the homeowners have no left over stain or other information on it. It seems to be a translucent finish but I'm unsure if it's oil or water based.
Looks like a buildup of old stain as it has a slight sheen. This means it dried on top of the wood. Harder to remove and maintain.
I think it is Sikkens SRD or the Cetok DEK. Hard to say for sure.
(@crsschk)
Thank you. That's kind of what I was assuming. It's in pretty good shape really, no peeling or anything indicative of a solid colored stain. So likely the strip\brighten route best way to go?
Strip off as much as possible, sand the rest of needed, brighten the wood when done. The current coating is thick so it will most likely need the sanding to remove fully.
