Suggestions for dec...
Suggestions for deck in South Texas next to a pool?
(@angeladl)
I have read review after review trying to decide on the best prep and stain for our deck, only to end up with more questions than answers. Hoping someone is willing to help. 😕
We replaced the horizontal floor boards on our deck (approx. 900 sq ft) in the spring of 2013. We used pressure-treated pine and intended to stain last spring so that it had enough time to dry out and accept the stain, but timing didn't work and here we are having not touched it since installation.
Deck is in San Antonio, TX and next to a chlorinated pool, so it takes a bit of a beating from heat/sun and chemicals. The original railings and spindles all remained with some low-quality stain that was applied about 4 years ago (don't remember the brand). I don't really care if the new stain perfectly matches what is on the railings, but would like to be able to give the railings a refresher with the new stain to make them look a little more consistent.
So my questions:
We pretty much have to sand down a few spots on the deck, we have some serious splintering and my toes paid the price last year. I've read that sanding is considered a no-no, but if I must, are there guidelines on how-to that won't make the grain reluctant to absorb the stain?
Which stain do you recommend for my circumstance? I was strongly leaning towards TWP based on reviews, but the guy I got a quote from specifically said we shouldn't use oil-based stains in our area because of the weather. His recommendation is Behr, which makes me shudder - but he'll apply whatever I purchase if I want to special order something. It's just the statement about oil vs water based that threw me for a loop...I haven't been able to find any info on the best types of stains for South Texas weather.
Is there anything that can be applied to the floor and the railings both without needing to strip the railings first? I'm not looking for perfection, just better than what is currently there.
Anything else I should be taking into consideration? Thank you all in advance for your help.
A few pictures for reference, forgive the leaves and pre-spring clean up appearance.
Your contractor is not very well versed on stain brands and types. I am sure he does quality work but being limited to HD for his products is a no no. Anyways you are much better off with a penetrating oil based stain for this in Texas. I would suggest these steps in order:
1. Light hand sand and splinters first.
2. Strip railings to remove as much as possible. I am guessing that 80% or so will come off.
3. Use a deck cleaner for the floor and light pressure wash
4. Let dry for 2+ days.
5. Stain with TWP in Pecan or Dark Oak to help blend rails and floor.
(@angeladl)
Perfect - thank you so much for your reply and guidance. TWP it is!
