Sikkens recoating?
(@sue14)
The records I inherited from the prior owner of my house show that the cedar deck was coated when built in 2008 with Sikkens SRD 077 stain. The deck is 300 sqft desk; it has a 100 sqft steps/railing. The deck and steps require recoating as the original stain is worn out in many places (no peeling). The railings look OK. Unfortunately I am in no position to do the job myself. I got some proposals and the quotes vary so much for the same job (with the same assumptions) that I am confused.
Each proposal shows two options:
a. Clean the deck, railings, steps with Trisodium Phosphate or sodium per carbonate and then recoat them with what was used initially (Sikkens SRD 077 stain); no power washer to be used. The quotes range from $400 to $1,000 including the stain.
OR
b. Sand everything (no stripping and brightening) and stain it again. The quotes range from $850 to $2,500, including the stain (assuming SRD).
These figures seem astronomical for the above mentioned size (comments from neighbors). Based on your industry experience what's a "reasonable" range for the charge for this job?
Thanks in advance for your help.
For a stripping, brightening, and restain with sikkens SRD you are looking at $800-$1000 for this size of deck. That is how we would quote based on your size.
(@sue14)
