beading on deck
(@xfactor70)
Hi there. I recently stained with TPW 100 and 1500 combined and put 2 coats on, but the stain appeared WET in a lot of areas and DRY in others..blotchy. I think I put the coats on too heavy...I put a 3rd coat on and now water BEADS on the wood.
I haven't stained the floor decking yet just the railings.
Can I strip/sand the rails and stain again before staining the floor boards?
Thank you..please advise.
(@xfactor70)
TWP rather.
If I strip the rails and then sand them? Brightner?
Did the over application the rails dry completely? If so I would let it be. When doing floors apply two coats wet on wet.
If you want to remove from rails you would strip and brighten for prep.
