restaining over cwf...
restaining over cwf uv
(@onjeffriv)
I have 25 gals of twp 100 sitting on my walk. 3 gallons of Clean and Bright Stripper. Started using stripper and contractor said not working. Call TWP retailer she said use garden sprayer at 5-1 ratio. We used it at 2-1 and nothing really. Called TWP manufacturers and they asked what I had previously sealed with. I used Flood CWF-UV. They said I could not use TWP over Flood CWf because short of sand blasting there was nothing the homeowner could do to strip the old CWF off. She recommended going back with CWF but they have changed the formula so much and it is much inferior than the original that I want to use a better semi transparent stain. The contractor has wasted a day already and wantrs to just bleach then spray with CWF. Any thoughts. Thanks.
CWF is strippabale. What brand was the stripper again?
(@onjeffriv)
Never heard of that brand. Might want to try something stronger like HD80.
(@onjeffriv)
The contractor is afraid the HD80 could ruin the metal roof.
HD80 does not harm metal.
