Product Recommendat...
Product Recommendation for Staining/Sealing a Redwood Fence
(@newbie)
Request help on the best product that I should be considering for staining/sealing the fence based on the following details.
Wood: Redwood (New fence which is approximately 6 months old).
Its a south facing lot with ample sunlight.
What would your recommendation be between Restore - A - Deck, Armstrong Clark and Timber Oil (Woodrich).  My goal is to pick the most reliable product that works for at least 2 - 3 years with minimal rework during this time frame. I am assuming that I should use a deck cleaner to clean the fence before applying the stainer. What would your recommendation be on the cleaner?
How much deck cleaner/stainer am I looking at for staining a 1250 sq.feet fence?
Thanks for your help!!!
Try the Armstrong Clark or the Restore-A-Deck Wood Stain. Prep with the RAD Cleaner and Brightener kit.
Amount needed varies by brand. About 1o gallons for 2 coats of AC and 12 gallons of two coats of the RAD Stain. This is assuming the fence is rough sawn cut. If smooth wood, use 2/3 of those amounts and only apply one coat.
2 RAD prep kits.
Did you count both sides of the fence in your sq footage? Length x Height x 2 is the way to measure a fence.
(@newbie)
Thanks for the prompt reply. I am not sure whether its rough sawn cut or smooth wood.
Enclosed are the pics of the fence. Is it possible to tell based on the attached pics?
Looks rough sawn cut.
