Permachink Lifeline...
Permachink Lifeline?
(@nolan)
Hi everyone,
New guy here. I live in south, central BC Canada. I've been in house construction and renos for years. Including some high end, timber frame homes.
But I'm really wanting to find a better stain that will stand up to our harsh climate here. Hot, dry summers, and long, cold winters with much freezing and thawing...all take a toll on wood finishes.
I really appreciate all the great info on this awesome website! A lot of hard work has gone into it, that's forsure!
But my problem is, before ordering something online, like Defy Extreme, I'd rather shop local. But only if I can find something worth using.
Locally, I can get Permachink Lifeline finishes. Does anyone know if these will stand up to our weather and look good...?
I can also get Sherwin Williams stains, but I guess they're not great?
I've used Sikkens mostly, but find it peels with it's build of film. On my own house, I tried their SRD, but it starts to get too much buildup after a maintenance coat or two.
I'm thinking, I want to use a water borne semi-transparent stain from now on. Then as it builds up with maintenance coats, the acrylic resins would stand up better than a buildup of oil resins. Am I correct?
Nolan
Unfortunately, we have no experience with the Permachink product. Being you are Canada, you are not going to find some of the better products in your local stores. The SW stains are not a favorite for us on decking, but in general, all exterior semi-trans stains will do much better on verticals. Problem is you want one the does not build up or film, and the only water-based stain that does this well is the Defy products. I am not sure of there is a good product for you to buy locally that does what you would like.
(@nolan)
I found that I can get Messmers stain locally. And like your review, it seems not bad. Especially if it's one of their tinted stains that would've probably done better with the UV rating, on your review.
But, am I going to find the same issue of too much build up, like with the SRD? I know it penetrates well, but after a few maintenance coats, there's gotta be a build up. Then with the oil based resins, that are more brittle than waterborne, acrylic resins, I'd get the peeling again. Correct?
Keeping in mind, I tend to keep up on my maintenance. I know, a bit rare these days...:)
So I wonder if I'd be better off with a water base stain. As it would build up, the softer resins would weather better, similar to a solid water base stain?
Maybe I'm overthinking again! lol
Please help before my mind blows!
Nolan
The Messmers will have less of buildup than the Sikkens SRD. Oil based stains, in general, will penetrate better than water based and film less because of this.
(@nolan)
 Thanks! Good to know.
So in the long run, would I be better to just go with Messmers, or order the Defy extreme?
The Messmers is a decent stain and is easy to reapply. The Defy Would most likely give better UV protection from fading.
(@nolan)
Thanks again!
Do you know anything about Cutek Extreme? (while we're at it) 🙂
Sorry, this is what happens when I can't work with a sore back....!
Posted by: Nolan
Thanks again!
Cutek was brought over from Australia and promised internal stabilization that would help harden the wood cells. I believe they add a silica that dives deep in the wood to react with the alkali, potentially stabilizing the cells. It is not the first gimmick type product to promise longer life for wood but is the latest. Other similar products attempted to make a claim and all were found out to not actually help. They added tints for their products to help with some color UV fading. Never actually used it though so have no idea on the viability to it.
(@nolan)
WOW! Doing some more research here on other forums and websites...what a lot of opposing views!
Thanks again for your side though. Why do you call these gimmicky finishes? Is it because oils don't dry and just wash out with the weather?....
One thing I found that sounds good maybe, is that Cutek can have trans oxide tints added to it. And I've read that these are the best UV blockers. What do think?
I wonder if Messmers has trans oxides added?
Almost all oil based stains contain trans-oxides if they have tint in the coating. It is gimmicky because their claims of internal hardening will not make the coating last any longer when it comes to UV protection.
(@nolan)
Thanks! 🙂
