New deck with some ...
New deck with some cedar and new cedar pergola,stain now or wait until spring?
33.4 K Views
 mel
(@mel)
Hello, I live in Niagara Falls NY and am in the process of building a new deck. I am using Trex for the decking boards and cedar on the stair risers, posts for the covered bbq area, some planters and also a pergola. I have been getting so many conflicting opinions on which route to take as far as treating the cedar that I am thoroughly confused and now paranoid that I am going to use the wrong product or do it at the wrong time and end up opening up a HUGE can of misery for myself creating unnecessary maintenance and work. I want to do it right the first time. Should I do nothing until spring, considering it is so late in the season and we are still several weeks from completion. It has been suggested to stain the pergola pieces after they are cut but before they are put together. I want the pergola to be still the cedar colour just slightly brighter but showing the grain and the cedar used in the deck probably a little darker, but still showing the grain. Any guidance you can give me with regards to the process I should use as well as which products to use would be greatly appreciated.
THANKYOU! THANKYOU! THANKYOU!
Yes on waiting until Spring at this point. Prep in the Spring with a deck cleaner and wood brightener. Look at a light cedar or honey color. Maybe TWP 1515 Honeytone or Armstrong Clark in Cedar Tone.
 mel
(@mel)
Thankyou, is there a deciding factor I should be considering when choosing between the TWP and the Armstrong other than who's colours I like best? I was initially thinking of using TWP, will one perform better over the other in my area considering the harsh winters and the fact it will be in full sun all afternoon. How long do you think before I will need to re-apply considering most of the surface area is vertical.
Either would last about the same since it is vertical wood. Verticals will last 3-4 years on most scenarios but horizontals will last about 2.
 DanC
(@danc)
How do you define a "new deck"? My deck is 4 years old, but I have just finished sanding off the old stain.
I'm planning on using TWP 100. Should I let the "new" wood age, or can I stain next week. We have low precipitation in Eastern Washington over the winter, but not zero.
Depends on the grit of paper you used. If 60 or 80 grit then lightly prep with a deck cleaner and wood brightener before staining. If you sanded smoother then you might need to let the wood season some first. Maybe a month or two then prep.
