Help with Deck stai...
Help with Deck staining again
(@vlapinta)
I stained my pressure treated wood deck with Flood solid stain about 5 years ago. The deck is due for stain again. I want to use the same stain but a darker color. What prep work do I need to do? I plan on power washing first. Do I need to do anything else before applying the darker stain?
Just pressure washing should be sufficient. Make sure to remove all dirt and any loose or peeling solid stain.
