Switching from pain...
Switching from painted to stained deck
(@wytas)
Looking to switch from a latex painted to oil stained deck. I live in Western, Massachusetts and we get all four seasons here. The deck is pretty old and weathered, no rot or algae growth. I was planning on power sanding the entire thing, and know that I will not be able to get all the paint out of the deck board imperfections (cracks, knots, dents, etc.) Was thinking of using SW SuperDeck, but after reading your articles I will probably change product. After sanding, do I need to pressure wash it? Would I need to then clean and brighten the deck? What would your recommended process be?
(@wytas)
Sorry, don't see where I can edit my post, but would it just be easier to prep the deck and go with latex/oil paint instead of stain?
If you want to switch you will need to power sand to remove and then clean and brighten for final prep of the wood.
(@wytas)
Would you recommend the 100 or 1500 series stain? I live in Massachusetts.
TWP 1500 for MA.
