Last weekend I rebuilt a portion of our fence (two section and gate). I used cedar pickets and rails and pressure treated 4x4 posts (all new wood - no paint/stain). The pickets and all the posts (except for one which I bought this last weekend) have been sitting in our garage for over a month. I am going to use Flood CWF Oil. My questions are:
1. I believe I can stain the cedar now (before it starts to weather.....what should I use (if anything) to prep it? Flood sells a Finish Remover and a Cleaner/Brightener. Maybe something else?
2. Should I wait to stain the pressure treated posts? If so, for how long and how should I prep those?
Thanks in advance!
I forgot to add.....the pickets are rough sawn cedar, the rails are "smooth" cedar 2x4s and the posts are "smooth" pressure treated 4x4s.
What does Flood say about prepping the new smooth wood? The rough wood can be stained now with no prep but the smooth wood most likely needs to weather and be prepped first.
It says I need both a cleaner and a brightener but that seems like overkill to me. I can see cleaning it to remove the "coating" but why the brightener too?
Neutralizes the cleaner and restore proper pH of the wood. Stains will look better and last longer.
How long should I wait before I stain the pressure treated. We've had very little rain and it's been four weeks since I built the fence. Thanks in advance!
Being a vertical fence and mostly rough wood, you can stain right away.
