Sanding and brightn...
Sanding and brightner ?
(@d-p-hardwoods)
I am a wood floor finisher and I have a client with roughly 1500sqft of tongue and grove pine decking he would like sanded and stained as well. The home is located in Michigan so I am thinking the TWP 100 SERIES. My question is after I sand and buff out the deck is a brightner even needed ? The surface area will be clean and they are choosing a lighter colored stain so I am not sure if I still need to open the grain up further as I am assuming that is part of what a brightner can do.
You should use both a deck cleaner and a wood brightener after sanding before applying the TWP.
(@d-p-hardwoods)
I am missing something. Why would I introduce chemicals to the wood (cleaner) then have to neutralize with the brightner if the material is clean ? I could see the brightner as it's a liquid it would raise the grain and open the pores a bit more for deeper penetration after I sanded and buffed it smooth. What can the cleaner do that my sanding equipment can not achieve ?
The cleaner will help remove all the sand dust that you will leave in the pores. Lifts it up so you can wash it out.
(@d-p-hardwoods)
Thank you very much for explaining the " why " I am a spoiled hardwood floor guy doing a favor for a client. I was contracted for the interior and this deck simply fell in my lap. So between my dustless systems and the final vacuum there would not be enough dust to fill a small cup left behind. I will try to post a pic when we are finished for you.
Great!
