Question about prop...
Question about proper prepping my situation
(@mikeloupier)
All WRC installed August in 2019. Left to weather until May 2020.
I used the RAD kit. Cleaner first, then powerwashed off, immediately followed by the brightener, then rinsed. I followed directions perfectly.
The entire deck is covered with white fuzzies. Even the rough sawn skirt.
Where did I screw up?
I read the article about wood fuzzies, but didn't think I'd have to do the entire deck.
After sanding, can I blow it off or do I need to use a brightener again?
Please advise.
The fuzzies happen from oxidation (graying) removal. You did not do anything wrong nor could this be prevented as the gray has to come off. After buffing or sanding off the affected areas, it would be best to brighten the wood again and rinse well with water.
(@mikeloupier)
@administrator
Thank you so much for the prompt reply. I have a palm sander and plan to use 60 grit.
Would it be better to use a random orbital or buffer? If no big difference, I'll just use my palm sander.
Also, should I sand the rough sawn boards?
Also, in the picture with the deep green grain, how can I get that out? Already treated twice with cleaner and power washed
Bi difference but if you spot sand you will have issues. The stain will absorb differently where you sand and that could lead to a blotchy finished appearance. Best to sand all. You cannot get the green out. Do not sand the rough sawn.
(@mikeloupier)
@administrator
Awesome, I do plan on sanding the whole thing.
I also have a dual-action polisher (for vehicles) that I can use.
Just trying to figure out the best sanding device for my application
