I have 1000 sq. foot ipe deck which was build last summer. we did not stain it yet. I want to do it right now. Can some body walk me trough the steps what should I do? And what products should I use. The deck in Philadelphia.
The biggest problem I have right know its sap spots on the deck. I thinking of using turpentine to remove them. any comments, suggestions?
Greg,
We have never found a product that removes sap well from wood. It is like glue. A solvent thinner works somewhat.
For the deck, there are numerous articles on the site about this. In general:
1. Clean and brighten wood for prep
2. Let dry for a couple of days.
3. Stain with a penetrating type stain.
For your area you should look at the Armstrong Clark.
what would you recommend for cleaning? Restore-A-Deck?
And another question; when I try to use turpentine to remove sap it did a job bit left spot on a deck. How can I remove this spot?
Greg, not sure on the spot. RAD kits will work for the cleaning.
I have an ipe deck that was stained two years ago. I dont think it was the right stain for the deck as i read that ipe should have penetrating oil. I want to use oil now but dont know if i need to strip it first or can i just clean it?
If there is still an older coating on the wood then you will need to strip. If not, use a deck cleaner.
