I recently redid my 22-year-old poorly maintained deck by stripping with Restore A Deck Stripper followed by RAD Brightener. I was quite impressed with the results (pictures below). In hindsight one change I would have made was that I would have stripped the deck, let it dry, and then spot stripped. This additional step is not b/c RAD Stripper did not work properly but b/c I had missed some hard to reach spots under the handrails and on the corners of the ballisters. I did find a pressure washer helped immensely after applying the stripped but did not need it following the brightener. The RAD products were easy to use and I will definitely use them next time.
Thanks you for posting pictures and experience with the RAD products.
