Staining the beams/...
Staining the beams/bridges under the deck
(@green)
I have a PVC deck and it's great. The support wood under the deck is pressure treated wood. For aesthetic purposes, I wanted to stain that PT wood with a solid color stain.
1. Is this a good idea? Are there any cons in doing this? The only thing I can think of is I would now have to do maintenance staining, whereas if I didn't stain, then I would just do nothing.
2. Since the PT wood is generally "protected" from the elements (vastly shaded, some spots would get wet during rain), would I still need to do a maintenance coat every 2-3 years? or would it last for 5-7+ years? I'll probably go with Defy or RAD.
1. You can use a solid stain if that is the look you want. Try this stain: https://www.deckstainhelp.com/restore-a-deck-solid-color-stain-review/
2. It will last longer than 2-3 years. Probably twice as long.
(@clove1)
I am a beginner, My stain doesnot support beams? Manns Classic Oak Wood Stain is a water-based wood stain, I used this treatment for Oak beams.
Not sure what your question is?
