New cedar deck stai...
New cedar deck stained with dark water marks
(@tammy)
I am located in Hamilton Ontario. Deck is covered by porch except for stairs. Stairs are pressure treat, porch decking is cedar.
Day#1: Used Behr#63 All in one wood cleaner on both stairs and cedar decking
Day#2: Lightly sanded and swept dry deck both stairs and deck
Day#3: Applied Behr transparent oil wood waterproofing on both stairs and deck
Day#5: Rained and water beaded into pools, which I though was good however...
Several days later I am noticing dark marks were water pooled, mostly on the edges all around the covered porch cedar decking, very little on the pressure treated wood stairs. As you can imagine this is very disappointing on a newly constructed porch and I it pains me to think I will need to sand the entire surface after my diligent prepping and following all product directions. Is is possible that I could use the Behr#64 wood stain and finish stripper and then start all over again? Would this remove the dark water marks?
No, it will not remove the dark water spots.
(@tammy)
Can you recommend what process I should now go with to repair?
Post a picture.
(@tammy)
You will have to remove the Behr. Strip and pressure wash. Brightener after.
(@tammy)
Can you tell me what appears to have gone wrong?
Honestly, it starts with the brand. Behr makes very poor deck products. It never cured before the rain hit it and then the water created separation spots in the uncured oil.
(@tammy)
Thank you very much. I am reluctant to try anything else without some backup experience. What would be a better product to use and can I use that brands stripper and brightener to remove the Behr?
Use the Restore A Deck Stripper/Brightener. Stain with the RAD stain or TWP stains.
(@tammy)
I was just in the middle of placing my online order for all of these products, $177 for the full order plus duty included in that. In my cart is the TWP200 Cedarstone 201, RAD stripper/brightener kit and the RAD booster. One question though.. do you think I would need the booster? Also, what is the difference between the RAD stripper/brightener kit and the Gemini RAD kit?
You will need to strip, not clean. The Gemini Kit is a cleaner/brightener. You might need the booster as it can be difficult to remove a newly applied stain. The Gel would help as well.
