Restaining patio ceiling
(@randydan)
The ceiling is pine decking with dougfir posts. It was stained 20 yrs ago with watco stain black walnut. Would RAD stripper be a good choice to remove and start over then restain with something better?
Randy
Watco is an interior wood finish. The RAD stripper is designed to remove exterior wood stains. I do not think it will work.
(@randydan)
Thanks for your reply. Does anyone have any advice on what I should do? Should I just try to clean it and restain with the same Watco and add a sealer in it?
(@randydan)
Well I used cabots stain remover and it worked on the watco stain. Then I used there brightener after. I seem to be getting some rough and raised grain after. Is this normal? So, if cabots worked on this, could I use RAD?
If the Cabot worked than the RAD should. Raising the grain can happen sometimes with a stripper. Sand lightly if needed when done.
