Los Angeles, CA VAC...
Los Angeles, CA VAC legal stain
(@r3swenson)
I live in Los Angeles, CA.
First project I built was a garden hose cabinet mounted to the outside garage wall under the eave. It has a flower box built in on top. It's all redwood untreated and is about 2-3 months old. Ready for sealing/stain.
I've read that a lot of the stains recommended are not legal in LA. VAC rules?
The TWP 1500 looks good??? What other options can I look into. The cabinet/flower box is in 90% shade. Up off the ground. Might get sprayed down once in a while, will have water in the planter box but will drain overflow down a rail and off the end.
I believe you have a couple of options for LA area: TWP 1500 or the Armstrong Clark
