3 story deck
(@bwinter)
I'm about to embark on a huge deck restoration on a 3 story deck that has had no stain on it since it was built 8 years ago. What I was concerned with was starting on the top deck and having the cleaner and brightner leak down to other decks before I can get to those and clean as well? Will it leave spots, streaks etc? Or shall I start at the bottom and work up?
Thanks in advance!
I think you are fine either way. We always go top deck first but we also move fast. Clean all first then brighten all when done and you should be okay. The brightener is easy and will even it all out when done.
