I had this deck built about 2.5 years ago in Rochester NY. The deck gets a lot of sun. I put a light colored stain on it at first and loved it. I realized the next year I put a interior stain (I'm not sure about the brand but the water did not bead up on it so I realized I did something wrong) on so I decided to re-stain, and darken in a bit. The second coat was applied in Spring of 2018 and applied it with a roller. I used Olympic Maximum stain. The color seems to have worn out over the past summer. I would love to start from scratch but I am not certain if that is possible/necessary.
Would you recommend chemicals to remove the stain?
If chemicals are the way to go...which ones? I have a Sherwin Williams nearby.
Should I sand it with floor sander?
Using another product before applying more stain? using a different application method?
I would like to do this now. It is a rainy season in the 60-70's. Should I wait?
Thank you for taking the time to review my questions!
Use the Restore-A-Deck Stripper/Brightener kits: https://www.deckstainhelp.com/restore-a-deck-injectable-deck-stain-stripper-review/
While pressure washing for the prep. Restain after with a penetrating stain.
