Thank you. Ok, so if i want some uv protection so the deck does not turn gray, what do you recommend?
In order to minimize labor and efforts, if possible, i would prefer to use a product that is a stain and sealer in one.
Thanks again.
jessefs
Admin,
In case it helps, here is a photo of my deck.
thanks
I've got a new 7ft cedar fence, just installed a month ago. The posts are PT pine. It's just alongside 1 property line. I live in Indiana. During the months that leaves are on the trees, which is about 6-7 months here, one side of the fence will get zero sun, the other will get sun from about 11a.m. to 6p.m. Since my property and the surrounding properties are shaded, the ground stays moist year round unless we are in a drought. No mildew/mold on the fence yet since it's new, however I do occasionally have to scrub small areas of green mildew off my cedar siding.
I hate to cover the beautiful fence with a solid or semi-solid stain already. The house is stained dark brown. I'm leaning towards transparent, natural stain. However everything I'm reading is saying that offers little UV protection. So I assume the cedar will gray about as quickly with or without? Since cedar is very rot resistant, is there any benefit to even using a transparent stain? From what I've been reading here, I'm leaning towards leaving it untreated, clean it well once a year, and then years down the road if I don't like the weathered gray I could start a solid stain. I'm just looking for some thoughts, advice, or personal experience with cedar fencing.
Jessefs, look for Defy Extreme in Natural Pine or Armstrong clark in Amber.
jm30, if you want to prevent graying then I would look at a light colored tint such as TWP 1515 Honeytone or Armstrong Clark in Amber. It will last about 3-4 years for a vertical fence.
what stain would be best for timberframe. exterior douglas fir.
Quote from dpscout on April 20, 2013, 23:14
TWP 1500 would be a good option.
I have moved into a new home that was built in 2007. My best guess is the deck has been neglected since the house was built. It looks like it was stained when the deck was built. I'm currently installing new railings and plan to stain the railings a different stain "color" than the deck boards. I will at least wait till early fall to before I stain. I will strip the old stain (and rest of deck to aid in cleaning) that remains and brighten the wood.
Here are my 5 answers:
1. Live 60 miles North of NYC
2. Half of deck is Fully covered with a roof, the other half is in full sun
3. Pressure treated pine (#1 high grade very few knots)
4. Some mildew or mold exists after 6 yrs. I would say a minor concern.
5. Not sure what hold stain was, but full sun half has some old stain left on deckboards and railings.
My main question is, I want to use a white stain (not solid) to show the wood grain for the railings and need help choosing a brand (I see Penofin blue label as the only option). Do you have a suggestion for the color I want? I plan to go with either TWP1500 or Defy for my deck boards, but neither of these come in the white color I want for my railings.
Thank you for your help.
There is no options that I know of for a white wash look for a deck stain. Sorry.
I live in Central, CA where it gets very hot in the summer. Rain and moisture is almost non-existent. This is on the south side of house in full sun. Installing a cedar pergola and deck. Wood is new and most timber just cut from a mill in Northern, CA. I received it a week ago and was told by the supplier to cover it as it will fade, which I have done. I will be building in about a week. My question would be should I still clean and brighten the wood if it is just cut (it looks great right now)? Also, local big box suppliers have limited options on stains, basically Olympic, Cabot or Superdeck. I don't mind ordering and bringing in either Armstrong or TWP, any thoughts on choice based on my usage? I plan to grow vines up the pergola and across the top. I only have time to stain and preserve once and then will need to let nature take its course with the wood. Any thoughts advise appreciated.
Please read this article:
Thank you for the reply and I did read this article. Part of my uncertainty is that this article refers to new deck or wood in general, whereas the following article refers to Cedar specifically;
http://www.deckstainhelp.com/best-stain-for-new-cedar-deck/
I have read several other articles before finally deciding to make a post, this site is excellent by the way. The wood I am using is a re-sawn cut versus rough cut, but it is far from a smooth surface of a typical board you would buy. I would imagine it is still wise to use a cleaner/brightener if for no other reason than to open the pores for staining. With regards to the pergola, it would be much easier to stain the wood in advance of construction, especially with regards the shade planks on the top. I would like to know if it is best to stain cedar soon or wait a month (or longer) after construction. Thank you again for your assistance.
If you want to stain before install then at least clean/brighten then stain with Armstrong Clark or Timber Oil Brand. Worse case scenario is you will need to do some touch ups in a year since you are not really waiting for the wood to weather.
1. State you live in - Michigan
2. Full Shade, Partial Shade, or Full Sun - Partial shade
3. Type of Wood - pressure treated (lumber from homedepot or Lowes)
4. Mold or Mildew Issues -none
5. Main Issues with Previous Stains: I stained last year with Thompsons Water Seal stain. I treated the deck beforehand using a deck cleaner. As soon as the snow melted this year, I noticed that the stain was peeling off the deck in many spots even from the spindles. I am not really sure how to proceed i have over 500 square feet of deck and spent numerous hours working on it last year.
Hi, I live in south eastern Connecticut & have a deck that always gets partial shade. It is made from pressure treated pine. There is a great amount of mold & algae on all surfaces. I am getting it power washed & the guy doing it is recommending Thompson's Water Seal. The deck has never been properly cleaned in the 8 years since it was built. This is a rental property & I would like it to be as maintenance free as possible. It seems I should be looking at a sealer that penetrates rather than strictly coating. What do you suggest?
