									Behrs DeckOver - Wood Deck Stain Reviews				            </title>
            <link>https://forum.deckstainhelp.com/wood-deck-stain-reviews/behrs-deckover/</link>
            <lastBuildDate>Wed, 28 Oct 2026 14:59:00 +0000</lastBuildDate>
                        <title>Behrs DeckOver</title>
                        <link>https://forum.deckstainhelp.com/wood-deck-stain-reviews/behrs-deckover/#post-9965</link>
                        <pubDate>Fri, 08 May 2015 14:19:40 +0000</pubDate>
                        <description><![CDATA[Strip off what you can. Sand any peeling areas off. This will prep for another solid stain.]]></description>
                        <content:encoded><![CDATA[Strip off what you can. Sand any peeling areas off. This will prep for another solid stain.]]></content:encoded>
						                            <category domain="https://forum.deckstainhelp.com/wood-deck-stain-reviews/">Wood Deck Stain Reviews</category>                        <dc:creator>Scott Paul ~ Restoring Wood &amp; Decks Since 1993</dc:creator>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/wood-deck-stain-reviews/behrs-deckover/#post-9965</guid>
                        <link>https://forum.deckstainhelp.com/wood-deck-stain-reviews/behrs-deckover/#post-9962</link>
                        <pubDate>Fri, 08 May 2015 12:23:18 +0000</pubDate>
                        <description><![CDATA[What would you suggest then for a deck in West Virginia in full sun made of pressure treated wood that doesn&#039;t have a mold or mildew problem?  It&#039;s about 10 years old and has Behrs solid sta...]]></description>
                        <content:encoded><![CDATA[What would you suggest then for a deck in West Virginia in full sun made of pressure treated wood that doesn't have a mold or mildew problem?  It's about 10 years old and has Behrs solid stain on it that's peeling on the horizontals.  Thanks for you help.]]></content:encoded>
						                            <category domain="https://forum.deckstainhelp.com/wood-deck-stain-reviews/">Wood Deck Stain Reviews</category>                        <dc:creator>Debbie</dc:creator>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/wood-deck-stain-reviews/behrs-deckover/#post-9962</guid>
                        <link>https://forum.deckstainhelp.com/wood-deck-stain-reviews/behrs-deckover/#post-9959</link>
                        <pubDate>Thu, 07 May 2015 20:32:46 +0000</pubDate>
                        <description><![CDATA[If you just cover the Behr it will be easier but it will not fix the problem so it will peel again. Sanding is very hard though to remove a solid stain.]]></description>
                        <content:encoded><![CDATA[If you just cover the Behr it will be easier but it will not fix the problem so it will peel again. Sanding is very hard though to remove a solid stain.]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/wood-deck-stain-reviews/behrs-deckover/#post-9959</guid>
                        <link>https://forum.deckstainhelp.com/wood-deck-stain-reviews/behrs-deckover/#post-9956</link>
                        <pubDate>Thu, 07 May 2015 14:03:48 +0000</pubDate>
                        <description><![CDATA[Should I just cover the peeled places with more Behr?  Or should I sand the whole deck to get up the solid stain?  Thanks for your advice.  This is a great forum!]]></description>
                        <content:encoded><![CDATA[Should I just cover the peeled places with more Behr?  Or should I sand the whole deck to get up the solid stain?  Thanks for your advice.  This is a great forum!]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/wood-deck-stain-reviews/behrs-deckover/#post-9956</guid>
                        <link>https://forum.deckstainhelp.com/wood-deck-stain-reviews/behrs-deckover/#post-9953</link>
                        <pubDate>Thu, 07 May 2015 12:03:43 +0000</pubDate>
                        <description><![CDATA[That will peel as well.]]></description>
                        <content:encoded><![CDATA[That will peel as well.]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/wood-deck-stain-reviews/behrs-deckover/#post-9953</guid>
                        <link>https://forum.deckstainhelp.com/wood-deck-stain-reviews/behrs-deckover/#post-9947</link>
                        <pubDate>Wed, 06 May 2015 17:03:24 +0000</pubDate>
                        <description><![CDATA[I used Behrs solid color stain three years ago and the horizontal pieces look terrible.  It was rated for 30 years!  (Yeah, right!)  Since I can&#039;t see the wood grain anyway, what about using...]]></description>
                        <content:encoded><![CDATA[I used Behrs solid color stain three years ago and the horizontal pieces look terrible.  It was rated for 30 years!  (Yeah, right!)  Since I can't see the wood grain anyway, what about using porch paint?]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/wood-deck-stain-reviews/behrs-deckover/#post-9947</guid>
                        <link>https://forum.deckstainhelp.com/wood-deck-stain-reviews/behrs-deckover/#post-9660</link>
                        <pubDate>Tue, 23 Sep 2014 19:21:05 +0000</pubDate>
                        <description><![CDATA[Nothing lasts what they claim. 2-3 years is the max you will get on a deck and many times it us much less then that. As contractors we prefer semi-transparents stains that penetrate into the...]]></description>
                        <content:encoded><![CDATA[Nothing lasts what they claim. 2-3 years is the max you will get on a deck and many times it us much less then that. As contractors we prefer semi-transparents stains that penetrate into the wood, show natural wood grain, and allow ease of future applications. Any of the higher rated stains that we review will work well.]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/wood-deck-stain-reviews/behrs-deckover/#post-9660</guid>
                        <link>https://forum.deckstainhelp.com/wood-deck-stain-reviews/behrs-deckover/#post-9656</link>
                        <pubDate>Tue, 23 Sep 2014 15:33:52 +0000</pubDate>
                        <description><![CDATA[my mother has a very old deck that she wants to use deck over or rust-oleum restore on.  All of the reviews look terrible for this type of product, in ease of application, look, and durabili...]]></description>
                        <content:encoded><![CDATA[my mother has a very old deck that she wants to use deck over or rust-oleum restore on.  All of the reviews look terrible for this type of product, in ease of application, look, and durability.  Does anyone know of a product that would work well on an old deck?  She wants me to do the work for her, and of course I don't want to spend a full-time week doing it.]]></content:encoded>
						                            <category domain="https://forum.deckstainhelp.com/wood-deck-stain-reviews/">Wood Deck Stain Reviews</category>                        <dc:creator>helenolson</dc:creator>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/wood-deck-stain-reviews/behrs-deckover/#post-9656</guid>
                        <link>https://forum.deckstainhelp.com/wood-deck-stain-reviews/behrs-deckover/#post-9077</link>
                        <pubDate>Tue, 13 May 2014 00:16:56 +0000</pubDate>
                        <description><![CDATA[Our local ABC news in the Tampa Bay area just had a deck stain spot in conjunction with Consumers Reports and they highly recommended Behr stains.]]></description>
                        <content:encoded><![CDATA[Our local ABC news in the Tampa Bay area just had a deck stain spot in conjunction with Consumers Reports and they highly recommended Behr stains.]]></content:encoded>
						                            <category domain="https://forum.deckstainhelp.com/wood-deck-stain-reviews/">Wood Deck Stain Reviews</category>                        <dc:creator>hms</dc:creator>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/wood-deck-stain-reviews/behrs-deckover/#post-9077</guid>
                        <link>https://forum.deckstainhelp.com/wood-deck-stain-reviews/behrs-deckover/#post-8709</link>
                        <pubDate>Wed, 21 Aug 2013 20:01:07 +0000</pubDate>
                        <description><![CDATA[Remove the Behr first and stain with Armstrong Clark in a semi-solid color for your high UV dock and decks.]]></description>
                        <content:encoded><![CDATA[Remove the Behr first and stain with Armstrong Clark in a semi-solid color for your high UV dock and decks.]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/wood-deck-stain-reviews/behrs-deckover/#post-8709</guid>
