									What to do when stripping doesnt remove everything? - Deck Stain Stripping Questions and Answers				            </title>
            <link>https://forum.deckstainhelp.com/deck-stain-stripping-questions-and-answers/what-to-do-when-stripping-doesnt-remove-everything/</link>
            <lastBuildDate>Wed, 28 Oct 2026 13:10:05 +0000</lastBuildDate>
                        <title>What to do when stripping doesnt remove everything?</title>
                        <link>https://forum.deckstainhelp.com/deck-stain-stripping-questions-and-answers/what-to-do-when-stripping-doesnt-remove-everything/#post-9156</link>
                        <pubDate>Sat, 31 May 2014 11:26:22 +0000</pubDate>
                        <description><![CDATA[60-80 grit]]></description>
                        <content:encoded><![CDATA[60-80 grit]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-stripping-questions-and-answers/what-to-do-when-stripping-doesnt-remove-everything/#post-9156</guid>
                        <link>https://forum.deckstainhelp.com/deck-stain-stripping-questions-and-answers/what-to-do-when-stripping-doesnt-remove-everything/#post-9150</link>
                        <pubDate>Thu, 29 May 2014 01:23:21 +0000</pubDate>
                        <description><![CDATA[For sanding cedar with an orbital floor sander, what grit sand paper would you recommend?]]></description>
                        <content:encoded><![CDATA[For sanding cedar with an orbital floor sander, what grit sand paper would you recommend?]]></content:encoded>
						                            <category domain="https://forum.deckstainhelp.com/deck-stain-stripping-questions-and-answers/">Deck Stain Stripping Questions and Answers</category>                        <dc:creator>jimct</dc:creator>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-stripping-questions-and-answers/what-to-do-when-stripping-doesnt-remove-everything/#post-9150</guid>
                        <link>https://forum.deckstainhelp.com/deck-stain-stripping-questions-and-answers/what-to-do-when-stripping-doesnt-remove-everything/#post-9108</link>
                        <pubDate>Wed, 21 May 2014 16:08:17 +0000</pubDate>
                        <description><![CDATA[For a floor sander, which would you recommend, orbital or drum?
	Also when I do stain it, can I do 2 coats or should I wait a year?
	Thanks...Jim]]></description>
                        <content:encoded><![CDATA[For a floor sander, which would you recommend, orbital or drum?<br />
	Also when I do stain it, can I do 2 coats or should I wait a year?<br />
	Thanks...Jim]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-stripping-questions-and-answers/what-to-do-when-stripping-doesnt-remove-everything/#post-9108</guid>
                        <link>https://forum.deckstainhelp.com/deck-stain-stripping-questions-and-answers/what-to-do-when-stripping-doesnt-remove-everything/#post-9104</link>
                        <pubDate>Wed, 21 May 2014 13:28:52 +0000</pubDate>
                        <description><![CDATA[Yes you will need to sand off the rest. Belt or floor sander. Wait a month then clean and brighten before applying the TWP.]]></description>
                        <content:encoded><![CDATA[Yes you will need to sand off the rest. Belt or floor sander. Wait a month then clean and brighten before applying the TWP.]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-stripping-questions-and-answers/what-to-do-when-stripping-doesnt-remove-everything/#post-9104</guid>
                        <link>https://forum.deckstainhelp.com/deck-stain-stripping-questions-and-answers/what-to-do-when-stripping-doesnt-remove-everything/#post-9103</link>
                        <pubDate>Wed, 21 May 2014 02:28:13 +0000</pubDate>
                        <description><![CDATA[I have a 24x16 ft cedar deck I am stripping a solid stain off of. I&#039;m using a behr product and also neutralizer afterwords (bought it before I found this site).  Using it with a power washer...]]></description>
                        <content:encoded><![CDATA[I have a 24x16 ft cedar deck I am stripping a solid stain off of. I'm using a behr product and also neutralizer afterwords (bought it before I found this site).  Using it with a power washer I was able to remove about 95&#37;. How should I get the rest off?  For the railings I was going to use a ros.  For the main deck what would you recommend?  Should a rent a large sander? Is that difficult to use? The deck is about 17 years old.  <br />
	Also I'm thinking about using the TWP 1500.  Should I wait a month if I sand?<br />
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-stripping-questions-and-answers/what-to-do-when-stripping-doesnt-remove-everything/#post-9103</guid>
