									Stripping Olympic Semi-Transparent - Deck Stain Stripping Questions and Answers				            </title>
            <link>https://forum.deckstainhelp.com/deck-stain-stripping-questions-and-answers/stripping-olympic-semi-transparent/</link>
            <lastBuildDate>Wed, 09 Sep 2026 14:16:13 +0000</lastBuildDate>
                        <title>Stripping Olympic Semi-Transparent</title>
                        <link>https://forum.deckstainhelp.com/deck-stain-stripping-questions-and-answers/stripping-olympic-semi-transparent/#post-8264</link>
                        <pubDate>Mon, 06 May 2013 21:56:57 +0000</pubDate>
                        <description><![CDATA[Oils are much easier to strip then water based stains. The steps are correct.]]></description>
                        <content:encoded><![CDATA[Oils are much easier to strip then water based stains. The steps are correct.]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-stripping-questions-and-answers/stripping-olympic-semi-transparent/#post-8264</guid>
                        <link>https://forum.deckstainhelp.com/deck-stain-stripping-questions-and-answers/stripping-olympic-semi-transparent/#post-8254</link>
                        <pubDate>Sun, 05 May 2013 22:20:41 +0000</pubDate>
                        <description><![CDATA[So basically strip it the best I can with the RAD stripper and then spot sand trouble areas?  I am pretty sure the Olympic is an oil-based stain...in your experience is this easier to strip ...]]></description>
                        <content:encoded><![CDATA[So basically strip it the best I can with the RAD stripper and then spot sand trouble areas?  I am pretty sure the Olympic is an oil-based stain...in your experience is this easier to strip than the water-based?<br />
	My plan of attack should then be (?):<br />
	1.  Strip with RAD stripper<br />
	2.  Let dry<br />
	3.  Spot sand problem areas<br />
	4.  Brighten<br />
	5.  Let dry<br />
	6.  Apply stain<br />
	Thanks again!<br />]]></content:encoded>
						                            <category domain="https://forum.deckstainhelp.com/deck-stain-stripping-questions-and-answers/">Deck Stain Stripping Questions and Answers</category>                        <dc:creator>goldenzephyr</dc:creator>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-stripping-questions-and-answers/stripping-olympic-semi-transparent/#post-8254</guid>
                        <link>https://forum.deckstainhelp.com/deck-stain-stripping-questions-and-answers/stripping-olympic-semi-transparent/#post-8253</link>
                        <pubDate>Sun, 05 May 2013 21:23:22 +0000</pubDate>
                        <description><![CDATA[Olympic water based stain is difficult to strip. Best to apply the RAD Stripper, pressure wash, repeat as needed, and sand any remaining as needed.]]></description>
                        <content:encoded><![CDATA[Olympic water based stain is difficult to strip. Best to apply the RAD Stripper, pressure wash, repeat as needed, and sand any remaining as needed.]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-stripping-questions-and-answers/stripping-olympic-semi-transparent/#post-8253</guid>
                        <link>https://forum.deckstainhelp.com/deck-stain-stripping-questions-and-answers/stripping-olympic-semi-transparent/#post-8252</link>
                        <pubDate>Sun, 05 May 2013 20:57:22 +0000</pubDate>
                        <description><![CDATA[I am planning on stripping the terrible finish of Olympic semi-transparent oil-based stain off my deck this year.  I plan on using the RAD stripper based on reviews.  If I am correct, I can ...]]></description>
                        <content:encoded><![CDATA[I am planning on stripping the terrible finish of Olympic semi-transparent oil-based stain off my deck this year.  I plan on using the RAD stripper based on reviews.  If I am correct, I can spray on with a pump sprayer (I have no pressure washer).  Should I also scrub with a deck brush as it is applied?  How long should it sit to strip adequately?  I plan on using the RAD brightener afterwards as well.  Any tips on applying or using this?<br />
	Great site by the way!  Been very helpful already!]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-stripping-questions-and-answers/stripping-olympic-semi-transparent/#post-8252</guid>
