									striping semi solid cabot - Deck Stain Stripping Questions and Answers				            </title>
            <link>https://forum.deckstainhelp.com/deck-stain-stripping-questions-and-answers/striping-semi-solid-cabot/</link>
            <lastBuildDate>Wed, 28 Oct 2026 11:14:09 +0000</lastBuildDate>
                        <title>striping semi solid cabot</title>
                        <link>https://forum.deckstainhelp.com/deck-stain-stripping-questions-and-answers/striping-semi-solid-cabot/#post-9259</link>
                        <pubDate>Thu, 26 Jun 2014 13:51:11 +0000</pubDate>
                        <description><![CDATA[It will not go away naturally but it will be easier to s rip off the rest after naturally weathering for a few months. Wait until Fall and use the Restore A Deck Stain stripper to remove. Us...]]></description>
                        <content:encoded><![CDATA[It will not go away naturally but it will be easier to s rip off the rest after naturally weathering for a few months. Wait until Fall and use the Restore A Deck Stain stripper to remove. Use their brightener when done.]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-stripping-questions-and-answers/striping-semi-solid-cabot/#post-9259</guid>
                        <link>https://forum.deckstainhelp.com/deck-stain-stripping-questions-and-answers/striping-semi-solid-cabot/#post-9257</link>
                        <pubDate>Thu, 26 Jun 2014 10:48:50 +0000</pubDate>
                        <description><![CDATA[I have an IPE deck that has been stained several times with Cabot clear semi-solid oil stain.  This time I had it professionally stripped and stained but it looks terrible with blotchy areas...]]></description>
                        <content:encoded><![CDATA[I have an IPE deck that has been stained several times with Cabot clear semi-solid oil stain.  This time I had it professionally stripped and stained but it looks terrible with blotchy areas.  The guy said that there is residual stain that he can't remove.  He said that I will need to let "nature" take care of it and with time the residual product will go away.  Is this right?  Is there a product out there that will take care of this?]]></content:encoded>
						                            <category domain="https://forum.deckstainhelp.com/deck-stain-stripping-questions-and-answers/">Deck Stain Stripping Questions and Answers</category>                        <dc:creator>jackhubb</dc:creator>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-stripping-questions-and-answers/striping-semi-solid-cabot/#post-9257</guid>
                        <link>https://forum.deckstainhelp.com/deck-stain-stripping-questions-and-answers/striping-semi-solid-cabot/#post-8571</link>
                        <pubDate>Mon, 15 Jul 2013 23:00:33 +0000</pubDate>
                        <description><![CDATA[You will need to sand. Water based acrylics are the most difficult type to remove. Even more so when a semi-solid. Basically you are trying to remove a paint and strippers will not remove pa...]]></description>
                        <content:encoded><![CDATA[You will need to sand. Water based acrylics are the most difficult type to remove. Even more so when a semi-solid. Basically you are trying to remove a paint and strippers will not remove paints.]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-stripping-questions-and-answers/striping-semi-solid-cabot/#post-8571</guid>
                        <link>https://forum.deckstainhelp.com/deck-stain-stripping-questions-and-answers/striping-semi-solid-cabot/#post-8565</link>
                        <pubDate>Mon, 15 Jul 2013 02:49:15 +0000</pubDate>
                        <description><![CDATA[it is an acrylic water base stain. I ordered some restore a deck striper, results not much better. any suggestions?]]></description>
                        <content:encoded><![CDATA[it is an acrylic water base stain. I ordered some restore a deck striper, results not much better. any suggestions?]]></content:encoded>
						                            <category domain="https://forum.deckstainhelp.com/deck-stain-stripping-questions-and-answers/">Deck Stain Stripping Questions and Answers</category>                        <dc:creator>FRANK</dc:creator>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-stripping-questions-and-answers/striping-semi-solid-cabot/#post-8565</guid>
                        <link>https://forum.deckstainhelp.com/deck-stain-stripping-questions-and-answers/striping-semi-solid-cabot/#post-8552</link>
                        <pubDate>Thu, 11 Jul 2013 12:05:29 +0000</pubDate>
                        <description><![CDATA[What brand is the semi-solid stain? Was it oil based or water based?]]></description>
                        <content:encoded><![CDATA[What brand is the semi-solid stain? Was it oil based or water based?]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-stripping-questions-and-answers/striping-semi-solid-cabot/#post-8552</guid>
                        <link>https://forum.deckstainhelp.com/deck-stain-stripping-questions-and-answers/striping-semi-solid-cabot/#post-8549</link>
                        <pubDate>Wed, 10 Jul 2013 04:48:15 +0000</pubDate>
                        <description><![CDATA[Im tryed using Behr deck striper a stiff brisle brush and a regular garden hose and had very little success.Any suggestions on what product would be the most effective on a semi solid stain?]]></description>
                        <content:encoded><![CDATA[Im tryed using Behr deck striper a stiff brisle brush and a regular garden hose and had very little success.Any suggestions on what product would be the most effective on a semi solid stain?]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-stripping-questions-and-answers/striping-semi-solid-cabot/#post-8549</guid>
