									Stain Stripper darkened wood considerably - Deck Stain Stripping Questions and Answers				            </title>
            <link>https://forum.deckstainhelp.com/deck-stain-stripping-questions-and-answers/stain-stripper-darkened-wood-considerably/</link>
            <lastBuildDate>Thu, 22 Oct 2026 14:09:32 +0000</lastBuildDate>
                        <title>RE: Stain Stripper darkened wood considerably</title>
                        <link>https://forum.deckstainhelp.com/deck-stain-stripping-questions-and-answers/stain-stripper-darkened-wood-considerably/#post-12792</link>
                        <pubDate>Mon, 22 Jul 2019 12:09:09 +0000</pubDate>
                        <description><![CDATA[All deck stain strippers will raise the pH of the wood and darken the color. That is the main reason you have to use a wood brightener after to neutralize and lighten back the pH balance to ...]]></description>
                        <content:encoded><![CDATA[<p>All deck stain strippers will raise the pH of the wood and darken the color. That is the main reason you have to use a wood brightener after to neutralize and lighten back the pH balance to the natural color.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-stripping-questions-and-answers/stain-stripper-darkened-wood-considerably/#post-12792</guid>
                        <title>Stain Stripper darkened wood considerably</title>
                        <link>https://forum.deckstainhelp.com/deck-stain-stripping-questions-and-answers/stain-stripper-darkened-wood-considerably/#post-12787</link>
                        <pubDate>Sun, 21 Jul 2019 15:28:53 +0000</pubDate>
                        <description><![CDATA[Hi all,  I have a 2 year old house with wood on the front. After this past Canadian winter the wood started graying and the sealer started failing. I used a Behr cleaner with a nylon brush t...]]></description>
                        <content:encoded><![CDATA[<p>Hi all, </p><p> </p><p>I have a 2 year old house with wood on the front. After this past Canadian winter the wood started graying and the sealer started failing.</p><p> </p><p>I used a Behr cleaner with a nylon brush to clean before water sealing but instead the finish started stripping.</p><p> </p><p>At this point I decided to use a stripper to remove the rest of the sealer and just reseal. </p><p> </p><p>I used Olympic stripper and tested in the bottom right corner.  It's very watery so it doesn't stay on the vertical surface very well.   After following the directions, I rinsed off and the wood was just a dark dark brown.  Nylon brush scrubbed and it eventually took the wood fibers out of the wood, and after drying a few days is still a gray color.</p><p>Any advice is appreciated after my little Sunday morning task turned into a big project.</p><p>I have no idea why the stripper is turning my word dark dark brown.  </p><p>Also is there anything I can do to ensure the stone floor at my entryway doesn't get discolored?</p><p> </p><p>825,824,823</p>]]></content:encoded>
						                            <category domain="https://forum.deckstainhelp.com/deck-stain-stripping-questions-and-answers/">Deck Stain Stripping Questions and Answers</category>                        <dc:creator>NO_CARRIER</dc:creator>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-stripping-questions-and-answers/stain-stripper-darkened-wood-considerably/#post-12787</guid>
