									Restaining patio ceiling - Deck Stain Stripping Questions and Answers				            </title>
            <link>https://forum.deckstainhelp.com/deck-stain-stripping-questions-and-answers/restaining-patio-ceiling/</link>
            <lastBuildDate>Wed, 28 Oct 2026 11:56:05 +0000</lastBuildDate>
                        <title>Restaining patio ceiling</title>
                        <link>https://forum.deckstainhelp.com/deck-stain-stripping-questions-and-answers/restaining-patio-ceiling/#post-8701</link>
                        <pubDate>Tue, 20 Aug 2013 20:53:04 +0000</pubDate>
                        <description><![CDATA[If the Cabot worked than the RAD should. Raising the grain can happen sometimes with a stripper. Sand lightly if needed when done.]]></description>
                        <content:encoded><![CDATA[If the Cabot worked than the RAD should. Raising the grain can happen sometimes with a stripper. Sand lightly if needed when done.]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-stripping-questions-and-answers/restaining-patio-ceiling/#post-8701</guid>
                        <link>https://forum.deckstainhelp.com/deck-stain-stripping-questions-and-answers/restaining-patio-ceiling/#post-8700</link>
                        <pubDate>Tue, 20 Aug 2013 14:46:18 +0000</pubDate>
                        <description><![CDATA[Well I used cabots stain remover and it worked on the watco stain.  Then I used there brightener after.  I seem to be getting some rough and raised grain after.  Is this normal?  So, if cabo...]]></description>
                        <content:encoded><![CDATA[Well I used cabots stain remover and it worked on the watco stain.  Then I used there brightener after.  I seem to be getting some rough and raised grain after.  Is this normal?  So, if cabots worked on this, could I use RAD?]]></content:encoded>
						                            <category domain="https://forum.deckstainhelp.com/deck-stain-stripping-questions-and-answers/">Deck Stain Stripping Questions and Answers</category>                        <dc:creator>randydan</dc:creator>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-stripping-questions-and-answers/restaining-patio-ceiling/#post-8700</guid>
                        <link>https://forum.deckstainhelp.com/deck-stain-stripping-questions-and-answers/restaining-patio-ceiling/#post-8649</link>
                        <pubDate>Wed, 07 Aug 2013 15:17:35 +0000</pubDate>
                        <description><![CDATA[Thanks for your reply.  Does anyone have any advice on what I should do?  Should I just try to clean it and restain with the same Watco and add a sealer in it?
	Thanks]]></description>
                        <content:encoded><![CDATA[Thanks for your reply.  Does anyone have any advice on what I should do?  Should I just try to clean it and restain with the same Watco and add a sealer in it?<br />
	Thanks]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-stripping-questions-and-answers/restaining-patio-ceiling/#post-8649</guid>
                        <link>https://forum.deckstainhelp.com/deck-stain-stripping-questions-and-answers/restaining-patio-ceiling/#post-8646</link>
                        <pubDate>Wed, 07 Aug 2013 00:15:14 +0000</pubDate>
                        <description><![CDATA[Watco is an interior wood finish. The RAD stripper is designed to remove exterior wood stains. I do not think it will work.]]></description>
                        <content:encoded><![CDATA[Watco is an interior wood finish. The RAD stripper is designed to remove exterior wood stains. I do not think it will work.]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-stripping-questions-and-answers/restaining-patio-ceiling/#post-8646</guid>
                        <link>https://forum.deckstainhelp.com/deck-stain-stripping-questions-and-answers/restaining-patio-ceiling/#post-8641</link>
                        <pubDate>Tue, 06 Aug 2013 15:35:54 +0000</pubDate>
                        <description><![CDATA[The ceiling is pine decking with dougfir posts.  It was stained 20 yrs ago with watco stain black walnut.  Would RAD stripper be a good choice to remove and start over then restain with some...]]></description>
                        <content:encoded><![CDATA[The ceiling is pine decking with dougfir posts.  It was stained 20 yrs ago with watco stain black walnut.  Would RAD stripper be a good choice to remove and start over then restain with something better?<br />
	Thanks<br />
	Randy]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-stripping-questions-and-answers/restaining-patio-ceiling/#post-8641</guid>
