									Remove solid stains from deck screws and between boards. - Deck Stain Stripping Questions and Answers				            </title>
            <link>https://forum.deckstainhelp.com/deck-stain-stripping-questions-and-answers/remove-solid-stains-from-deck-screws-and-between-boards/</link>
            <lastBuildDate>Wed, 22 Jul 2026 09:45:42 +0000</lastBuildDate>
                        <title>RE: Remove solid stains from deck screws and between boards.</title>
                        <link>https://forum.deckstainhelp.com/deck-stain-stripping-questions-and-answers/remove-solid-stains-from-deck-screws-and-between-boards/#post-13484</link>
                        <pubDate>Fri, 28 Aug 2020 15:25:17 +0000</pubDate>
                        <description><![CDATA[You could try a stripper and see if that works. Make sure to brighten all after.]]></description>
                        <content:encoded><![CDATA[You could try a stripper and see if that works. Make sure to brighten all after.]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-stripping-questions-and-answers/remove-solid-stains-from-deck-screws-and-between-boards/#post-13484</guid>
                        <title>Remove solid stains from deck screws and between boards.</title>
                        <link>https://forum.deckstainhelp.com/deck-stain-stripping-questions-and-answers/remove-solid-stains-from-deck-screws-and-between-boards/#post-13483</link>
                        <pubDate>Fri, 28 Aug 2020 14:18:56 +0000</pubDate>
                        <description><![CDATA[Hi,
Firstly just wanted to say how great this forum is and appreciate all the advice provided!
I recently moved into a new place and the previous owners had used a solid white stain on...]]></description>
                        <content:encoded><![CDATA[Hi,
I recently moved into a new place and the previous owners had used a solid white stain on a brand new cedar deck which is now about 5-7 years old. It was a Behr stain which was peeling so my plan was to power sand it all off and apply a transparent or semi-transparent stain which would show the grain a bit more.
My issue is after power sanding there’s still solid white stain where the screws were counter sunk and also between the deck boards. I think I can get between the deck boards with a multi-tool or dremel but what would be the best way to tackle this? Is trying a stain remover worth trying for these small spots where the screw holes are?  The deck is about 500sq.ft.  
Thanks in advance! 
1139]]></content:encoded>
						                            <category domain="https://forum.deckstainhelp.com/deck-stain-stripping-questions-and-answers/">Deck Stain Stripping Questions and Answers</category>                        <dc:creator>Zee</dc:creator>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-stripping-questions-and-answers/remove-solid-stains-from-deck-screws-and-between-boards/#post-13483</guid>
