									Help Removing Pittsburgh Revitalize - Deck Stain Stripping Questions and Answers				            </title>
            <link>https://forum.deckstainhelp.com/deck-stain-stripping-questions-and-answers/help-removing-pittsburgh-revitalize/</link>
            <lastBuildDate>Sun, 01 Nov 2026 13:56:33 +0000</lastBuildDate>
                        <title>RE: Help Removing Pittsburgh Revitalize</title>
                        <link>https://forum.deckstainhelp.com/deck-stain-stripping-questions-and-answers/help-removing-pittsburgh-revitalize/#post-13286</link>
                        <pubDate>Mon, 18 May 2020 23:25:29 +0000</pubDate>
                        <description><![CDATA[The only way to remove is to power sand it off. You should stay away from the Behr, it is a poor stain.]]></description>
                        <content:encoded><![CDATA[The only way to remove is to power sand it off. You should stay away from the Behr, it is a poor stain.]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-stripping-questions-and-answers/help-removing-pittsburgh-revitalize/#post-13286</guid>
                        <link>https://forum.deckstainhelp.com/deck-stain-stripping-questions-and-answers/help-removing-pittsburgh-revitalize/#post-13285</link>
                        <pubDate>Mon, 18 May 2020 23:19:01 +0000</pubDate>
                        <description><![CDATA[I have also used Revitalize for my deck coating.Installed 2 heavy coats at least 10 years ago. It has stayed intact with no chipping or flaking. I am replacing with Behr Premium Deck coating...]]></description>
                        <content:encoded><![CDATA[I have also used Revitalize for my deck coating.Installed 2 heavy coats at least 10 years ago. It has stayed intact with no chipping or flaking. I am replacing with Behr Premium Deck coating . I tried to remove with a Sun Joe 2300PSI pressure washer. Only seen some removal after putting on a 0 degree head. Stared to damage the Redwood. Is my only other option to use an Orbital sander or a higher PSI rated Pressure washer? Thank You 
Danny]]></content:encoded>
						                            <category domain="https://forum.deckstainhelp.com/deck-stain-stripping-questions-and-answers/">Deck Stain Stripping Questions and Answers</category>                        <dc:creator>Scubaskiba</dc:creator>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-stripping-questions-and-answers/help-removing-pittsburgh-revitalize/#post-13285</guid>
                        <title>Help Removing Pittsburgh Revitalize</title>
                        <link>https://forum.deckstainhelp.com/deck-stain-stripping-questions-and-answers/help-removing-pittsburgh-revitalize/#post-9819</link>
                        <pubDate>Mon, 09 Mar 2015 19:51:15 +0000</pubDate>
                        <description><![CDATA[Products like this are not strippable. Your only option is to sand it off or replace the wood. Sorry :(]]></description>
                        <content:encoded><![CDATA[Products like this are not strippable. Your only option is to sand it off or replace the wood. Sorry :(]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-stripping-questions-and-answers/help-removing-pittsburgh-revitalize/#post-9819</guid>
                        <link>https://forum.deckstainhelp.com/deck-stain-stripping-questions-and-answers/help-removing-pittsburgh-revitalize/#post-9818</link>
                        <pubDate>Mon, 09 Mar 2015 18:44:43 +0000</pubDate>
                        <description><![CDATA[We put a coating of Pittsburgh Revitalize wood and concrete resurfacer on our deck about 2 years ago. Our deck was in decent shape...it looked a bit old and worn, and only had a few cracks a...]]></description>
                        <content:encoded><![CDATA[We put a coating of Pittsburgh Revitalize wood and concrete resurfacer on our deck about 2 years ago. Our deck was in decent shape...it looked a bit old and worn, and only had a few cracks and minor rotten spots, so I figured a product like this would be ideal. It wasn't. It was a nightmare to apply, and then began to flake off after only a few months. Given a total lack of time and money, I haven't gotten around to fixing it until now, but it needs to be done.<br />
	My question is: Since this is not your typical "stain," how do I go about removing it? The FAQs for the product say to never use a pressure washer, so would that remove it? Or do I need to go through the stripping process? I'm hoping to avoid that if possible, because our deck has a lot of nooks and crannies, and stripping every inch of this stuff would be a TON of work. Not to mention the cost of buying all those different products. <br />
	Any help I could get with removing this stuff would be greatly appreciated. Thank you.]]></content:encoded>
						                            <category domain="https://forum.deckstainhelp.com/deck-stain-stripping-questions-and-answers/">Deck Stain Stripping Questions and Answers</category>                        <dc:creator>dtayl913</dc:creator>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-stripping-questions-and-answers/help-removing-pittsburgh-revitalize/#post-9818</guid>
