									Does new stain require stripping? - Deck Stain Stripping Questions and Answers				            </title>
            <link>https://forum.deckstainhelp.com/deck-stain-stripping-questions-and-answers/does-new-stain-require-stripping/</link>
            <lastBuildDate>Wed, 27 May 2026 22:32:32 +0000</lastBuildDate>
                        <title>RE: Does new stain require stripping?</title>
                        <link>https://forum.deckstainhelp.com/deck-stain-stripping-questions-and-answers/does-new-stain-require-stripping/#post-12445</link>
                        <pubDate>Mon, 08 Apr 2019 13:54:40 +0000</pubDate>
                        <description><![CDATA[That is correct on coverage and all stain brands are close to that coverage amount. Try to stain within two weeks of prep.]]></description>
                        <content:encoded><![CDATA[<p>That is correct on coverage and all stain brands are close to that coverage amount. Try to stain within two weeks of prep.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-stripping-questions-and-answers/does-new-stain-require-stripping/#post-12445</guid>
                        <link>https://forum.deckstainhelp.com/deck-stain-stripping-questions-and-answers/does-new-stain-require-stripping/#post-12444</link>
                        <pubDate>Mon, 08 Apr 2019 12:21:23 +0000</pubDate>
                        <description><![CDATA[My deck is prepped and ready to be stained. I had planned to use Armstrong Clark semi-transparent stain. It says it covers 150-200 sf/gallon. This is significantly less than most stains - do...]]></description>
                        <content:encoded><![CDATA[<p>My deck is prepped and ready to be stained. I had planned to use Armstrong Clark semi-transparent stain. It says it covers 150-200 sf/gallon. This is significantly less than most stains - does this sound right? Any idea why such small coverage? </p><p>I used the cleaner/brightener yesterday. Is it okay if I can't stain for another week?</p>]]></content:encoded>
						                            <category domain="https://forum.deckstainhelp.com/deck-stain-stripping-questions-and-answers/">Deck Stain Stripping Questions and Answers</category>                        <dc:creator>April</dc:creator>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-stripping-questions-and-answers/does-new-stain-require-stripping/#post-12444</guid>
                        <link>https://forum.deckstainhelp.com/deck-stain-stripping-questions-and-answers/does-new-stain-require-stripping/#post-12408</link>
                        <pubDate>Thu, 28 Mar 2019 18:14:31 +0000</pubDate>
                        <description><![CDATA[Thank you!]]></description>
                        <content:encoded><![CDATA[<p>Thank you!</p><p> </p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-stripping-questions-and-answers/does-new-stain-require-stripping/#post-12408</guid>
                        <link>https://forum.deckstainhelp.com/deck-stain-stripping-questions-and-answers/does-new-stain-require-stripping/#post-12407</link>
                        <pubDate>Thu, 28 Mar 2019 18:05:00 +0000</pubDate>
                        <description><![CDATA[You cannot apply a different brand of stain over this. It will not soak in or adhere correctly.Use a deck stripper and pressure wash. Sand only if needed. Brighten when done.]]></description>
                        <content:encoded><![CDATA[<p>You cannot apply a different brand of stain over this. It will not soak in or adhere correctly.</p><p>Use a deck stripper and pressure wash. Sand only if needed. Brighten when done.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-stripping-questions-and-answers/does-new-stain-require-stripping/#post-12407</guid>
                        <link>https://forum.deckstainhelp.com/deck-stain-stripping-questions-and-answers/does-new-stain-require-stripping/#post-12406</link>
                        <pubDate>Thu, 28 Mar 2019 18:00:51 +0000</pubDate>
                        <description><![CDATA[Okay. Not trying to be difficult, but why? So that the new stain adheres?Am I correct with rest of process? Brighten, wash off with hose, sand if needed and stain?]]></description>
                        <content:encoded><![CDATA[<p>Okay. Not trying to be difficult, but why? So that the new stain adheres?</p><p>Am I correct with rest of process? Brighten, wash off with hose, sand if needed and stain?</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-stripping-questions-and-answers/does-new-stain-require-stripping/#post-12406</guid>
                        <link>https://forum.deckstainhelp.com/deck-stain-stripping-questions-and-answers/does-new-stain-require-stripping/#post-12400</link>
                        <pubDate>Thu, 28 Mar 2019 15:18:07 +0000</pubDate>
                        <description><![CDATA[You have to strip the old deck.]]></description>
                        <content:encoded><![CDATA[<p>You have to strip the old deck.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-stripping-questions-and-answers/does-new-stain-require-stripping/#post-12400</guid>
                        <title>Does new stain require stripping?</title>
                        <link>https://forum.deckstainhelp.com/deck-stain-stripping-questions-and-answers/does-new-stain-require-stripping/#post-12399</link>
                        <pubDate>Thu, 28 Mar 2019 13:20:22 +0000</pubDate>
                        <description><![CDATA[I have a half new, half old deck that needs to be stained to look like one. The new decking was put on last summer so it is weathered and ready to be stained. The old decking has been staine...]]></description>
                        <content:encoded><![CDATA[<p>I have a half new, half old deck that needs to be stained to look like one. The new decking was put on last summer so it is weathered and ready to be stained. The old decking has been stained for at least 10 years, sometimes with water based, sometimes with old, sometimes with a hybrid. It always seems to accept the stain without having been stripped or sanded. It is currently weathered and dry and seems ready to be stained.</p><p>I plan to use AC semi-transparent stain in either Rustic Brown or Black Walnut and will be sampling them today. I would prefer not to use semi-solid. If this stain matches the woods up enough for my liking, do I have to strip the old decking or can I just clean, brighten and stain?594,595,596</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-stripping-questions-and-answers/does-new-stain-require-stripping/#post-12399</guid>
