									Deck Plan - Deck Stain Stripping Questions and Answers				            </title>
            <link>https://forum.deckstainhelp.com/deck-stain-stripping-questions-and-answers/deck-plan/</link>
            <lastBuildDate>Sun, 04 Oct 2026 05:27:30 +0000</lastBuildDate>
                        <title>Deck Plan</title>
                        <link>https://forum.deckstainhelp.com/deck-stain-stripping-questions-and-answers/deck-plan/#post-9320</link>
                        <pubDate>Wed, 09 Jul 2014 23:34:20 +0000</pubDate>
                        <description><![CDATA[Thanks for all the info.... I believe my stain is solid stain...Will hd 80 still work to strip it all? Maybe it&#039;s semi solid I don&#039;t know for sure.  If it&#039;ll remove the stain, I should proba...]]></description>
                        <content:encoded><![CDATA[Thanks for all the info.... I believe my stain is solid stain...Will hd 80 still work to strip it all? Maybe it's semi solid I don't know for sure.  If it'll remove the stain, I should probably strip the entire deck instead of sanding?]]></content:encoded>
						                            <category domain="https://forum.deckstainhelp.com/deck-stain-stripping-questions-and-answers/">Deck Stain Stripping Questions and Answers</category>                        <dc:creator>scamel</dc:creator>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-stripping-questions-and-answers/deck-plan/#post-9320</guid>
                        <link>https://forum.deckstainhelp.com/deck-stain-stripping-questions-and-answers/deck-plan/#post-9316</link>
                        <pubDate>Wed, 09 Jul 2014 22:47:23 +0000</pubDate>
                        <description><![CDATA[Use a deck stain stripper and a pressure washer. you will need to strip a few times to get it all off.]]></description>
                        <content:encoded><![CDATA[Use a deck stain stripper and a pressure washer. you will need to strip a few times to get it all off.]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-stripping-questions-and-answers/deck-plan/#post-9316</guid>
                        <link>https://forum.deckstainhelp.com/deck-stain-stripping-questions-and-answers/deck-plan/#post-9312</link>
                        <pubDate>Wed, 09 Jul 2014 00:10:06 +0000</pubDate>
                        <description><![CDATA[How would I prep the previously stained surfaces?  Sanding would be time prohibitive with two small kids in the house]]></description>
                        <content:encoded><![CDATA[How would I prep the previously stained surfaces?  Sanding would be time prohibitive with two small kids in the house]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-stripping-questions-and-answers/deck-plan/#post-9312</guid>
                        <link>https://forum.deckstainhelp.com/deck-stain-stripping-questions-and-answers/deck-plan/#post-9311</link>
                        <pubDate>Wed, 09 Jul 2014 00:07:08 +0000</pubDate>
                        <description><![CDATA[You would want a solid color deck stain for this. Cabot or Flood.]]></description>
                        <content:encoded><![CDATA[You would want a solid color deck stain for this. Cabot or Flood.]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-stripping-questions-and-answers/deck-plan/#post-9311</guid>
                        <link>https://forum.deckstainhelp.com/deck-stain-stripping-questions-and-answers/deck-plan/#post-9307</link>
                        <pubDate>Tue, 08 Jul 2014 20:56:27 +0000</pubDate>
                        <description><![CDATA[I have one follow up question.... What would be a good product to use for the white railings and vertical surfaces.  I was going to paint it white with an exterior paint, but I&#039;m reading peo...]]></description>
                        <content:encoded><![CDATA[I have one follow up question.... What would be a good product to use for the white railings and vertical surfaces.  I was going to paint it white with an exterior paint, but I'm reading people use white stain.]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-stripping-questions-and-answers/deck-plan/#post-9307</guid>
                        <link>https://forum.deckstainhelp.com/deck-stain-stripping-questions-and-answers/deck-plan/#post-9281</link>
                        <pubDate>Fri, 04 Jul 2014 03:04:01 +0000</pubDate>
                        <description><![CDATA[Some of the deck power washed in these pics]]></description>
                        <content:encoded><![CDATA[Some of the deck power washed in these pics<br />
	<img src="http://www.deckstainhelp.com/wp-content/uploads/2014/07/m80x8-20140703_180141.jpg" alt="" /><br />
	<img src="http://www.deckstainhelp.com/wp-content/uploads/2014/07/n87ma-20140703_180210.jpg" alt="" /><br />
	<img src="http://www.deckstainhelp.com/wp-content/uploads/2014/07/43001-20140703_180151.jpg" alt="" />]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-stripping-questions-and-answers/deck-plan/#post-9281</guid>
                        <link>https://forum.deckstainhelp.com/deck-stain-stripping-questions-and-answers/deck-plan/#post-9276</link>
                        <pubDate>Thu, 03 Jul 2014 12:17:50 +0000</pubDate>
                        <description><![CDATA[Perfect and two toned decks look great as well. Much easier for future maintenance. Would love to see pictures during this process!]]></description>
                        <content:encoded><![CDATA[Perfect and two toned decks look great as well. Much easier for future maintenance. Would love to see pictures during this process!]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-stripping-questions-and-answers/deck-plan/#post-9276</guid>
                        <link>https://forum.deckstainhelp.com/deck-stain-stripping-questions-and-answers/deck-plan/#post-9273</link>
                        <pubDate>Wed, 02 Jul 2014 17:01:23 +0000</pubDate>
                        <description><![CDATA[I just purchased a house with a 1200 sq foot 2 tier deck coated with a solid stain(manufacturer unknown) that is peeling on all the horrizontal surfaces, however on the vertical surfaces the...]]></description>
                        <content:encoded><![CDATA[I just purchased a house with a 1200 sq foot 2 tier deck coated with a solid stain(manufacturer unknown) that is peeling on all the horrizontal surfaces, however on the vertical surfaces the stain is still in perfect condition.  After much investigating on this site I finally have a plan:<br />
	1. Power wash all loose/peeling stain off the deck<br />
	2. Countersink Nails/fix loose board and Sand horrizontal floor surfaces down with a rented random orbital rectangular floor sander, fixing any cupping and removing all leftover solids stain.  Use palm sander where necessary.<br />
	3.  Clean and brighten floor using Restore-A-Deck or equivalent<br />
	4.  Stain Horrizontal floor surfaces with TWP 100 <br />
	5.  Paint vertial surfaces and railings with white outdoor paint for a   2 tone look (which my wife and I like)<br />
	Am I missing any steps?  Is anything out of order?<br />
	I appreciate any advise.<br />
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-stripping-questions-and-answers/deck-plan/#post-9273</guid>
