									White semi-transparent stain - Deck Stain Questions and Answers				            </title>
            <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/white-semi-transparent-stain/</link>
            <lastBuildDate>Fri, 23 Oct 2026 10:36:12 +0000</lastBuildDate>
                        <title>RE: White semi-transparent stain</title>
                        <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/white-semi-transparent-stain/#post-13027</link>
                        <pubDate>Mon, 30 Sep 2019 20:06:35 +0000</pubDate>
                        <description><![CDATA[Thanks, again for your response. That answers all of my questions for now.]]></description>
                        <content:encoded><![CDATA[<p>Thanks, again for your response. That answers all of my questions for now.</p>]]></content:encoded>
						                            <category domain="https://forum.deckstainhelp.com/deck-stain-questions-and-answers/">Deck Stain Questions and Answers</category>                        <dc:creator>JimA</dc:creator>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-questions-and-answers/white-semi-transparent-stain/#post-13027</guid>
                        <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/white-semi-transparent-stain/#post-13024</link>
                        <pubDate>Mon, 30 Sep 2019 20:02:30 +0000</pubDate>
                        <description><![CDATA[You can use the RAD solid stain for all but you cannot use a semi-transparent for the floor unless you remove 100% of the current white paint.]]></description>
                        <content:encoded><![CDATA[<p>You can use the RAD solid stain for all but you cannot use a semi-transparent for the floor unless you remove 100% of the current white paint.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-questions-and-answers/white-semi-transparent-stain/#post-13024</guid>
                        <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/white-semi-transparent-stain/#post-13023</link>
                        <pubDate>Mon, 30 Sep 2019 19:50:52 +0000</pubDate>
                        <description><![CDATA[After posting my last comment, I noticed the review of Restore-a-Deck solid stain. It looks like this is a via option for me. Either for the entire deck, or for just the railings if, in fact...]]></description>
                        <content:encoded><![CDATA[<p>After posting my last comment, I noticed the review of Restore-a-Deck solid stain. It looks like this is a via option for me. Either for the entire deck, or for just the railings if, in fact with proper preparation, I can use a semi-transparent stain for the flooring. Any comments? </p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-questions-and-answers/white-semi-transparent-stain/#post-13023</guid>
                        <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/white-semi-transparent-stain/#post-13020</link>
                        <pubDate>Mon, 30 Sep 2019 15:34:08 +0000</pubDate>
                        <description><![CDATA[Thanks. I&#039;ve attached photos so you can see what my situation is. Note that most of the previous finish has already peeled off. Should I be able to use a semi-transparent stain if I pressure...]]></description>
                        <content:encoded><![CDATA[<p>900,899,898</p><p>Thanks. I've attached photos so you can see what my situation is. Note that most of the previous finish has already peeled off. Should I be able to use a semi-transparent stain if I pressure washed and sanded to remove the remaining finish?</p><p>If not, then do I have any options other than re-applying a paint or solid stain? (Note that I live in Wisconsin so I do not think that I am limited by VOCs.)</p><p>I ask the first question because if I can, in fact, use a semi-transparent stain if the wood is properly prepared then one option would be to finish the flooring in a wood stain and the railing with white paint.</p><p>Thanks, again, for your input.</p><p> </p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-questions-and-answers/white-semi-transparent-stain/#post-13020</guid>
                        <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/white-semi-transparent-stain/#post-13018</link>
                        <pubDate>Mon, 30 Sep 2019 07:00:17 +0000</pubDate>
                        <description><![CDATA[No there is not a quality white semi-trans and you cannot apply a semi-trans over the solid stain/paint that you have on now anyhow.]]></description>
                        <content:encoded><![CDATA[<p>No there is not a quality white semi-trans and you cannot apply a semi-trans over the solid stain/paint that you have on now anyhow.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-questions-and-answers/white-semi-transparent-stain/#post-13018</guid>
                        <title>White semi-transparent stain</title>
                        <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/white-semi-transparent-stain/#post-13016</link>
                        <pubDate>Sun, 29 Sep 2019 17:20:46 +0000</pubDate>
                        <description><![CDATA[I am refinishing a deck (pressure-treated pine) had has previously finished with either white paint or a white pigmented stain. I want to refinish it in white, since the railings are also wh...]]></description>
                        <content:encoded><![CDATA[<p>I am refinishing a deck (pressure-treated pine) had has previously finished with either white paint or a white pigmented stain. I want to refinish it in white, since the railings are also white and I think that it would be difficult to remove and restore them to the point that I could redo them with wood color. In addition, although 90+% of the original paint/stain is removed on the floor boards, there could still be some white in the knots, etc. that would be difficult to remove.</p><p>(I plan to pressure treat and clean the deck prior to staining but haven't yet decided if I will sand or not.)</p><p>My question is: is there a quality semi-transparent stain that is available in white. I notice that the big box stores carry semi-transparent white stains but I am leery of the quality of the products.</p><p>Thanks, in advance, for your response.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-questions-and-answers/white-semi-transparent-stain/#post-13016</guid>
