									Uneven Finish With Armstrong-Clark on Ipe Deck - Deck Stain Questions and Answers				            </title>
            <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/uneven-finish-with-armstrong-clark-on-ipe-deck/</link>
            <lastBuildDate>Tue, 06 Oct 2026 00:20:47 +0000</lastBuildDate>
                        <title>RE: Uneven Finish With Armstrong-Clark on Ipe Deck</title>
                        <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/uneven-finish-with-armstrong-clark-on-ipe-deck/#post-12595</link>
                        <pubDate>Tue, 28 May 2019 14:20:23 +0000</pubDate>
                        <description><![CDATA[Thanks]]></description>
                        <content:encoded><![CDATA[<p>Thanks</p>]]></content:encoded>
						                            <category domain="https://forum.deckstainhelp.com/deck-stain-questions-and-answers/">Deck Stain Questions and Answers</category>                        <dc:creator>cbsimpson</dc:creator>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-questions-and-answers/uneven-finish-with-armstrong-clark-on-ipe-deck/#post-12595</guid>
                        <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/uneven-finish-with-armstrong-clark-on-ipe-deck/#post-12592</link>
                        <pubDate>Mon, 27 May 2019 22:30:33 +0000</pubDate>
                        <description><![CDATA[Strip and brighten for prep.]]></description>
                        <content:encoded><![CDATA[<p>Strip and brighten for prep.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-questions-and-answers/uneven-finish-with-armstrong-clark-on-ipe-deck/#post-12592</guid>
                        <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/uneven-finish-with-armstrong-clark-on-ipe-deck/#post-12591</link>
                        <pubDate>Mon, 27 May 2019 13:55:07 +0000</pubDate>
                        <description><![CDATA[Thanks. What would you suggest I do next Spring?]]></description>
                        <content:encoded><![CDATA[<p>Thanks. What would you suggest I do next Spring?</p><p> </p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-questions-and-answers/uneven-finish-with-armstrong-clark-on-ipe-deck/#post-12591</guid>
                        <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/uneven-finish-with-armstrong-clark-on-ipe-deck/#post-12590</link>
                        <pubDate>Mon, 27 May 2019 12:36:13 +0000</pubDate>
                        <description><![CDATA[I believe the sanding created the uneven finish. If you do not sand it evenly, the stain will be uneven when applied. You cannot apply more stain at this point. Best to leave as is and deal ...]]></description>
                        <content:encoded><![CDATA[<p>I believe the sanding created the uneven finish. If you do not sand it evenly, the stain will be uneven when applied. You cannot apply more stain at this point. Best to leave as is and deal with it next Spring. The other option is to strip it off, brighten the wood and stain again.</p><p>Personally, we would do #1 as it doesn't look that bad and it will probably "tone" down and look more even in a month.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-questions-and-answers/uneven-finish-with-armstrong-clark-on-ipe-deck/#post-12590</guid>
                        <title>Uneven Finish With Armstrong-Clark on Ipe Deck</title>
                        <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/uneven-finish-with-armstrong-clark-on-ipe-deck/#post-12589</link>
                        <pubDate>Sun, 26 May 2019 15:39:49 +0000</pubDate>
                        <description><![CDATA[I live in Virginia and am a new subscriber. I have a seven year old ipe deck. It was originally finished with Sikkens and  a maintenance coat applied every year. Looked fabulous for the firs...]]></description>
                        <content:encoded><![CDATA[<p>690</p><p>I live in Virginia and am a new subscriber. I have a seven year old ipe deck. It was originally finished with Sikkens and  a maintenance coat applied every year. Looked fabulous for the first couple of years. Then started getting splotchy, dark and peeling in places. </p><p>Recently had it sanded down and stained with Armstrong-Clark Mahogany stain.  The problem is the finish is very uneven. (See attached photo.)</p><p>I should have done more research before beginning this project. I realize now that two mistakes were made.</p><p>1. No deck brightener or other treatment was applied after the sanding; they just vacuumed off the dust.</p><p>2. They applied the single coat of stain with rags rather than brushes or stain pads.</p><p>I don't know if either of these helped create the uneven finish. But, the real question is, what do I do now?</p><p>Should we apply a second coat? If so, what prep should be done before applying it?</p><p>I would greatly appreciate any other suggestions. Please help!</p><p>Thanks</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-questions-and-answers/uneven-finish-with-armstrong-clark-on-ipe-deck/#post-12589</guid>
