									Too hot to stain - Deck Stain Questions and Answers				            </title>
            <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/too-hot-to-stain/</link>
            <lastBuildDate>Tue, 10 Nov 2026 13:22:19 +0000</lastBuildDate>
                        <title>RE: Too hot to stain</title>
                        <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/too-hot-to-stain/#post-14825</link>
                        <pubDate>Mon, 24 Jun 2024 17:04:44 +0000</pubDate>
                        <description><![CDATA[It needs to be outside to properly cure and dry. Put it out there, and hopefully, it will all be good in a day or two.]]></description>
                        <content:encoded><![CDATA[
<p class="p1">I recently purchased TWP Pro-Series semi-transparent exterior wood stain. I have a composite deck with cedar handrail and spindles. The can said you can apply between 50-90 degrees. It was 90 degrees so I took the handrail off and applied the stain in my garage to get out of the hot sun. My problem is that it doesn't seem to be getting dry.<span class="Apple-converted-space">  </span>3 days now. I have since put it my basement in the air conditioning. I went to your website and it says it should be applied at 80 degrees or the wood<span class="Apple-converted-space">  </span>would "flash" (dry quickly on the surface and not soak in). What should I do next?</p>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-questions-and-answers/too-hot-to-stain/#post-14825</guid>
                        <title>Too hot to stain</title>
                        <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/too-hot-to-stain/#post-14823</link>
                        <pubDate>Mon, 24 Jun 2024 16:52:56 +0000</pubDate>
                        <description><![CDATA[I recently purchased TWP Pro-Series semi-transparent exterior wood stain. I have a composite deck with cedar handrail and spindles. The can said you can apply between 50-90 degrees. It was 9...]]></description>
                        <content:encoded><![CDATA[<p class="p1">I recently purchased TWP Pro-Series semi-transparent exterior wood stain. I have a composite deck with cedar handrail and spindles. The can said you can apply between 50-90 degrees. It was 90 degrees so I took the handrail off and applied the stain in my garage to get out of the hot sun. My problem is that it doesn't seem to be getting dry.<span class="Apple-converted-space">  </span>3 days now. I have since put it my basement in the air conditioning. I went to your website and it says it should be applied at 80 degrees or the wood<span class="Apple-converted-space">  </span>would "flash" (dry quickly on the surface and not soak in). What should I do next?</p>]]></content:encoded>
						                            <category domain="https://forum.deckstainhelp.com/deck-stain-questions-and-answers/">Deck Stain Questions and Answers</category>                        <dc:creator>krikro1952</dc:creator>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-questions-and-answers/too-hot-to-stain/#post-14823</guid>
