									Stain on the fence - Deck Stain Questions and Answers				            </title>
            <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/stain-on-the-fence/</link>
            <lastBuildDate>Tue, 29 Sep 2026 11:07:26 +0000</lastBuildDate>
                        <title>RE: Stain on the fence</title>
                        <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/stain-on-the-fence/#post-13468</link>
                        <pubDate>Tue, 25 Aug 2020 12:56:05 +0000</pubDate>
                        <description><![CDATA[The shelf life of opened containers is usually about 12 months or less. It will probably not last any longer.]]></description>
                        <content:encoded><![CDATA[The shelf life of opened containers is usually about 12 months or less. It will probably not last any longer.]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-questions-and-answers/stain-on-the-fence/#post-13468</guid>
                        <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/stain-on-the-fence/#post-13467</link>
                        <pubDate>Tue, 25 Aug 2020 12:39:23 +0000</pubDate>
                        <description><![CDATA[Thanks. Deck finished. Looks good and I hope it will not peel next year.
One more question regarding the left over stain. I have 3/4 of the can left. How long can I keep it in order to us...]]></description>
                        <content:encoded><![CDATA[Thanks. Deck finished. Looks good and I hope it will not peel next year.
One more question regarding the left over stain. I have 3/4 of the can left. How long can I keep it in order to use it again? Any particular way of keeping (temperature,...)?]]></content:encoded>
						                            <category domain="https://forum.deckstainhelp.com/deck-stain-questions-and-answers/">Deck Stain Questions and Answers</category>                        <dc:creator>sp</dc:creator>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-questions-and-answers/stain-on-the-fence/#post-13467</guid>
                        <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/stain-on-the-fence/#post-13448</link>
                        <pubDate>Fri, 07 Aug 2020 18:05:12 +0000</pubDate>
                        <description><![CDATA[You can only stain over the current stain if you use the same brand and color otherwise you will need to strip and brighten for prep. As for the deck, typically 48 hours after prep before st...]]></description>
                        <content:encoded><![CDATA[You can only stain over the current stain if you use the same brand and color otherwise you will need to strip and brighten for prep. As for the deck, typically 48 hours after prep before staining.]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-questions-and-answers/stain-on-the-fence/#post-13448</guid>
                        <title>Stain on the fence</title>
                        <link>https://forum.deckstainhelp.com/deck-stain-questions-and-answers/stain-on-the-fence/#post-13447</link>
                        <pubDate>Fri, 07 Aug 2020 14:57:49 +0000</pubDate>
                        <description><![CDATA[I live in Toronto. My deck and a fence constructed from PT boards 4 years ago have 4 - 5 hrs of sun per day. 3 years ago I used Behr clear transparent water based stain. After 3 years fence ...]]></description>
                        <content:encoded><![CDATA[I live in Toronto. My deck and a fence constructed from PT boards 4 years ago have 4 - 5 hrs of sun per day. 3 years ago I used Behr clear transparent water based stain. After 3 years fence is still looking ok and a deck peeled. I pressured cleaned the deck and sanded it and will use the same stain again. I also wanted to refresh the fence.
I used a very low pressure just to clean the dust and dirt from the fence. Can I stain the fence over the old stain?
Also after sanding the deck I cleaned the dust from the deck with low pressure. How much time should I allow for a deck to dry?
SP]]></content:encoded>
                        <guid isPermaLink="true">https://forum.deckstainhelp.com/deck-stain-questions-and-answers/stain-on-the-fence/#post-13447</guid>
